How to Dissasemble a Motor
7,227
26
32
Posted
Introduction: How to Dissasemble a Motor
its easy, try it!
Step 1: First,
Take the motor and pry the end cap off with a flat head screwdriver.
Step 2: Second,
Pull out the armature.
Step 3: Third,
Pull out the U" shaped piece of metal. (sorry about the crummy picture.)
Step 4: Fourth,
Pull out the magnets that are located on the sides of the inside of the motor shell.
Step 5: Fifth,
put the magnets back the way you took them out
Step 6: Sixth,
push the "U" shaped piece of metal back in
Step 7: Seventh,
put the armature in the way you took it out also.
Step 8: Eighth,
put the end cap back on
Step 9: Finally,
your done! hope you thought this was interesting.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
33 Comments
the title should say - how to behave like an oxymoron...
Out of curiosity, why would one want to do this?
im a nerd, why would a nerd do it, for the heck of it
thats the best way ive ever heard  it
what kind of motor is this, and how much do they cost?
pretty cheap, about $2 from wher i get them, you can get a 12 pack with alot of different kinds for $20. the motor is just a regular ol' motor, they are in almost all toys.
You can also "rebuild" electric motors and know very little about electricity, how to re-wrap a coil that is burned in two and not counting the loops, by clipping all the copper off "1 winding at a time" and saving it to "weigh it" then measuring its AWG or thickness, then you can calculate how much wire is used, buy and re-wrapping the coil using the same method as it was wrapped till you run out of wire,simple. Replacement brushes/wire can be bought at most electrical supply houses. and if using hobby motors it is good to experiment with capacitor and resistor effects on motor circuits too. learn a little about "PWM" "Make sure you buy enameled wrapping wire though!" you probably wont need this much, I do alot of repairs and sometimes you just cant replace the motor.
