how to dissasemble a motor
 by tecno geek
its easy, try it!
Step 1: First,
Take the motor and pry the end cap off with a flat head screwdriver.
damntourists says: Mar 8, 2008. 11:24 PM
Out of curiosity, why would one want to do this?
tecno geek (author) in reply to damntouristsMar 9, 2008. 6:27 AM
im a nerd, why would a nerd do it, for the heck of it
dylankunaikennedy in reply to tecno geekJun 7, 2011. 8:04 AM
lol
absolute zero in reply to tecno geekJan 2, 2010. 6:49 AM
thats the best way ive ever heard  it
Sagar Gondaliya in reply to tecno geekMar 16, 2009. 10:55 AM
amen
sexylezchick says: Apr 27, 2010. 2:01 AM
that was cool
Sergant Tinkers says: May 21, 2009. 6:07 PM
what kind of motor is this, and how much do they cost?
Stephen D. Alverez in reply to Sergant TinkersJun 14, 2009. 5:57 AM
pretty cheap, about $2 from wher i get them, you can get a 12 pack with alot of different kinds for $20. the motor is just a regular ol' motor, they are in almost all toys.
iamdenteddisk says: Oct 13, 2008. 11:17 PM
You can also "rebuild" electric motors and know very little about electricity, how to re-wrap a coil that is burned in two and not counting the loops, by clipping all the copper off "1 winding at a time" and saving it to "weigh it" then measuring its AWG or thickness, then you can calculate how much wire is used, buy and re-wrapping the coil using the same method as it was wrapped till you run out of wire,simple. Replacement brushes/wire can be bought at most electrical supply houses. and if using hobby motors it is good to experiment with capacitor and resistor effects on motor circuits too. learn a little about "PWM" "Make sure you buy enameled wrapping wire though!" you probably wont need this much, I do alot of repairs and sometimes you just cant replace the motor.
kanamin says: Jul 5, 2008. 1:06 AM
This should mention somewhere that it's a 130 size motor, common in small toys/devices. Other motors have different tab placements and shapes etc etc, and some have screws instead of tabs. You might want to do this to put in stronger magnets, different gauge wire for the armature, cleaning, etc etc.
Hands Without Shadows says: Mar 8, 2008. 2:55 PM
You didn't pull the brushes back up over the commutator. It wont work this way and you may have bent the springs.
tecno geek (author) in reply to Hands Without ShadowsJul 4, 2008. 1:36 PM
i tried, it works
tecno geek (author) in reply to Hands Without ShadowsMar 8, 2008. 3:02 PM
this is just a small hobby motor, it doesn't have any of that.
Andrew546 in reply to tecno geekMar 8, 2008. 9:44 PM
Actually, this motor does have brushes, they just take the form of copper strips that extend from the end bell to the commutator. They're actually designed in such a way that they'll slide up onto the commutator without having to be manipulated much, so you don't have to worry about pulling them onto the commutator.
tecno geek (author) in reply to Andrew546Mar 28, 2008. 12:31 PM
its just an armature with copper wires wrapped around, there is no brushes!!!!!!!!!!!!!!!!!!!!!!!!!
Andrew546 in reply to tecno geekMar 29, 2008. 2:10 PM
I can assure you, it does have brushes. It is physically impossible for a motor of this design (with the electromagnets on the armature and permanent magnets in the case) to work without brushes.
The brushes are very small and could easily be mistaken for something else, but they are there.
Brushless motors do exist, put they have permanent magnets on the armature, and electromagnets in the case. They also need a microchip to control them.
tecno geek (author) in reply to Andrew546Apr 3, 2008. 2:35 PM
im sorry, upon further inspection of my motors, i realized that you are right, it does have brushes. they are in the cap, i didn't understand the terms you were using, such as BRUSHES".
tecno geek (author) in reply to tecno geekApr 3, 2008. 2:39 PM
and i didnt bend the brushes, and it works. usually, i lift up the brushes and put them back over, but i figured out that they slide on they're own with a little push.
archeryfreak in reply to Andrew546Apr 2, 2008. 5:58 PM
your right because on the cap where the axle is put the brushes are attached to the cap
tecno geek (author) in reply to archeryfreakMay 19, 2008. 1:23 PM
cool
brammeke11 says: Jul 4, 2008. 12:37 AM
its a knex motor and turn that flash of when you take picture of something like that
freakinslop says: Jun 15, 2008. 9:24 AM
i did the same thing at science camp exept i threw the motor against a wall lol.
joey2542667 says: May 17, 2008. 3:23 PM
it's a generator not a motor
tecno geek (author) in reply to joey2542667May 18, 2008. 7:37 AM
its a hobby motor
joey2542667 in reply to tecno geekMay 19, 2008. 7:46 AM
hmmmmm.
tecno geek (author) says: Mar 18, 2008. 5:06 PM
please rate
LinuxH4x0r says: Mar 8, 2008. 3:11 PM
Cool! Now if only you could tell us how to rewind coils on industrial motors...
thearchitect in reply to LinuxH4x0rMar 9, 2008. 4:10 PM
My uncle does that for earning his life! Heck of a job. Lots of diagrams and custom work for every single motor... K.
LinuxH4x0r in reply to thearchitectMar 9, 2008. 6:06 PM
Cool! Instructable?
tecno geek (author) in reply to LinuxH4x0rMar 8, 2008. 3:46 PM
i'll work on it
GorillazMiko says: Mar 8, 2008. 2:56 PM
I've done this before. Very easy. :P Nice job, the pictures could be a bit more better, but I still get the idea.
tecno geek (author) in reply to GorillazMikoMar 8, 2008. 3:01 PM
thanks 4 the encouragement, appreciate it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
