How to Draw Lips
1,506
11
Posted in TechnologyArt
Introduction: How to Draw Lips
About: I love artwork and drawing x
quick and easy
Step 1: Draw the First Part of Your Grid
in the middle of your paper you need a 16cm wide and 8cm tall grid
Step 2: Divide Your Grid Into 8 Squares
draw a straight horizontal line going through the middle of your grid, then draw 3 evenly spaced out vertical lines
Step 3: Draw a Semi Circle in the Top 2 Middle Squares
make sure your semi circle fills the top 2 middle squares
Step 4: Draw Your Top Lip
it may sound difficult but its really easy... just draw a diagonal line going through the top right and left boxes, then to join them up your just using a little bit of a bumpy line :)
Step 5: Draw Your Bottom Lip
now from the bottom 2 outside squars you are basically doing the same thing as you did with the top lip but the only thing different about this one is you join the 2 diagonal lines up with a curved line
Step 6: Rub Out the Grid Behind Your Lips
you have to keep 1 line which is the line that seperates the top and bottom lip
Step 7: Draw Your Teeth
simples!
Step 8: Shade!
you need to shade your top and bottom lip and then colour in the semi circle (but not the teeth!)
Step 9: Now Show Off Your Wonderful Drawing!
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
