Introduction: How to Edit Action Replay Codes Part One
Picture of How to Edit Action Replay Codes Part One
have you ever played a videogame you just cant seem to beat?
i have the solution. hack the game with my guide.
part one: just simple editing to the ammount the code gives you
part two: comming soon
things you will need:
action replay(i use the one for my ds)
action replay codes
how to count in hexdecimal
a game system to use the action replay on(you can use a emulator but that is ilegal if you dont have the system or rom you are using)
next are only for action replay ds
action replay code manager
a text editor(i use notepad, if you dont make sure you can save the file as a .xml file)
Step 1: First Things First
Picture of First Things First
step one
get some codes for the game you want to hack. make sure they are simple codes like a health cheat and not a big complex code.
example of simple:
infinite rupees(zelda phamtom hourglass)
121ba4fe 0000270f
example of complex:
aimbot(metroid prime hunters(the code was to long so i am only going to put part of it))
e2000000 000004c8
e59f0308 e9204ffe
e2400004 e5d03000
e2401004 e5912000
e59f42f4 e1d440b0
e2044008 e3540000
1a000005 e3520001
0a000005 e2833001
e3a02001 e5812000
ea000001 e3a02000
e5812000 e2033003
e5c03000 e3a02ef3
e59f12b8 e5911000
e1510003 0a0000a3
e0000291 e0050293
e59f42a4 e0855004
e0844000 e5948000
e5959000 e0498008
e5949004 e595a004
e04a9009 e594a008
e5953008 e04aa003
e0000898 e0010a9a
e0800001 ef0d0000
e1a01009 e2016102
Step 2: Somthing You Need to Know
Picture of Somthing You Need to Know
I can not stress this enough people, normal codes can not delete your save file!!! it can only do that if your game deletes corrupt files. please check that.
every code that makes up the game gets turned or checked for at a certan time when you play the game. if the codes you made turned on the wrong time in your game, the game will think your save file is corrupt and not load it.
action replay codes are temperly in the fact that you can turn of the system and take out the acion replay and the code will no longer be in effect.
if your game things the save file is corrupt just turn of your system and run the game with out the code on. the game will go back to normal and load your save file.
to have the game load the code at the right time you need to see the next step.
Step 3: Activators
Picture of Activators
activators are the building blocks of every game. they are simply a line of code that tell the game to do the next line of code when a button is pressed.
this is how you get past the corrupt game problem.
put this line of code at the beginning of your code
94000130 fdff0000
if you put that line of code at the beginning you will see the code only happens if you press L(this is for ds(other system will have to figure out there activators on there own, sorry)
Step 4: The Code Ending
make sure that you end your code with this
d2000000 00000000
it just tells the game that this code ends here and not to combine it with the next code.
Step 5: What You All Have Been Waiting For!
ok so here is the meat of the instructable.
steps:
first few steps are for action replay ds only
open notepad
find your newest codelist (it should have the codes you want to edit in it)
open it in notepad
pay not atteaion to the .xml writing and just to the code on it.
(next steps for everyone)
fine the code you want to edit. i will use the code below to give an example
infinite lives(kirby squeak squad)
22261898 00000063
first lets add a activator
94000130 fdff0000
22261898 00000063
lets test the code... oops forgot to add the end.
now lets end it
94000130 fdff0000
22261898 00000063
d2000000 00000000
now lets test... yay it works, i get infinite lives but only when i press L
now lets change the ammount of lives(knowing how to count in hexdecimal will help you greatly)
here are the part of the code to focus on
94000130 fdff0000
22261898 00000063
d2000000 00000000
63 in hexdecimal=99. lets make it 50. 50=32 in hexdecimal.
so the code is
94000130 fdff0000
22261898 00000032
d2000000 00000000
now i still have infinite lives but 50 shows in the box that shows how many lives i have.
thats the basics. this is not limited to basic health cheats. you can use it on any code that is some what simple. just dont change the first 8 digets of the code or it will not work properly. if you change the second part of the code in a different code your results will be different. you might find the place were it changes the item or place the item is put.
i hope this helps! please comment and rate! post sugestions or things to add in the instructable.
happy hacking! :)
randofo (author)2008-02-14
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
teaaddict314 (author)randofo2008-02-15
lol
dsman195276 (author)teaaddict3142008-02-17
so do you like the instructable?
dsman195276 (author)teaaddict3142008-02-15
that was just because it did not have many pictures.
GASSYPOOTS (author)2011-12-20
not all codes end in D20000 000000
for example
walk through walls L+B
pokemon platinum(us)
94000130 fefd0000
12060b90 0000e00a
12060bf6 0000e001
12060c94 0000e008
Invader Biz (author)2011-11-22
im good at diamond pkmn
icunningham (author)2011-08-04
does the l button activator code work for dsi?
dsman195276 (author)icunningham2011-09-03
I don't see any reason why it wouldn't. It will definitely work in 'DS Mode', I don't know if it will work in 'DSi mode' but I don't imagine you'll be hacking any DSi exclusive games (Are there any?) DSMan195276
Kush_Slayer (author)2009-03-02
if i knew where zeld(the person who made that aimbot that you mentioned) lived i would probably punch him in the face, hacking online mode ruins the game(not saying its only zelds fault)
dsman195276 (author)Kush_Slayer2009-07-03
ya, the aim bot pretty much make it impossible for hackers to lose on wifi. it really stinks to because all they have to do is move, and pretty much nobody can tell it is really happening(though i have learned to be able to tell if someone is using it from how they move.) i only use it in multiplayer because sometimes it is fun to take out the bots in around 30 seconds, but it just makes wifi boring. but, i have to disagree about using all codes on wifi. there are some code that improve the game for everyone(the best one is changing mode of play(like changing it to survive instead of battle). not all hackers are bad :-P
Kush_Slayer (author)dsman1952762009-07-07
i like those later codes, to bad they dont have them for version 1.1 or i would use them
mettaurlover (author)Kush_Slayer2010-01-15
Actually, if you can hook it up to your computer, it WILL work. The systems use the same number of digits per section per line, and therefore the codes will work on any version of the software. Trust me; I've had every generation of these for the DS and they've all been the same size and format.
Kush_Slayer (author)mettaurlover2010-01-15
no, there is a version 1.0 and 1.1 for metroid prime hunters and on version 1.1 you would have to switch the codes to write to different parts of the memory, but you have to know where those parts of the memory are
dsman195276 (author)Kush_Slayer2009-07-08
sorry, i don't know if there is any way to make them into 1.1 codes. you could always play for a few days, and then see if i ever come on...
kameronriley (author)2009-11-13
grand theft auto chinatown wars
Search it in google. He is not here to make codes, just to tell you how to edit them. He is not here even to tell you how to make them, or to find them for you.
Mplinnc (author)2009-12-26
it dus not work
dsman195276 (author)kameronriley2009-11-13
What specifically does not work? Simply telling me that it does not work in bad spelling and punctuation does not help anyway, just makes you look lazy.
Now if you tell me what is wrong, then I can help you.
TarzanJr (author)2009-09-23
The easyiest way to summarize what some people are saying is we are not all inteligent like you are... so explain everything like we dont know what is going and if at all times explain why we are clicking and typing certain things so that if something goes wrong we can try and fix it ourselfs instead of bugging you about 24/7.... get it :D have fun dude i love this site it is alot of fun
Ideal_Ideas91 (author)2009-07-02
You know I always had a question about emulators. Now its illegal to have one if you dont have the system. Well what if you get the system then get the emulator but end up selling the system. What Then? Do you get rid of the emulator or what?
GEORGE41708 (author)2009-02-13
THIS IS SO HACKEN COOL!! LOL
Foaly7 (author)2008-10-13
Will "Older" codes work with D/P?
dsman195276 (author)Foaly72008-11-29
you can't interchange game codes if thats what you are talking about. stuff won't be in the same place in D/P as it is in the older games.
BalintRules (author)2008-11-29
The comment below me is long, and when I say long I mean long
ojochris (author)2008-02-24
Dude, you do Action Replay and KNEX?! So Do I! P.S. Nice Job, This makes the way I Hack my Action Replay look like F****n' Quantim Physics or something...
dsman195276 (author)ojochris2008-04-15
just wondering, how do you hack your action replay codes? i want to know if you do it the same way i do.
ojochris (author)dsman1952762008-04-15
same way, pretty much. Just a lot harder. lol
ok, just wondering.
dsman195276 (author)ojochris2008-02-24
thanks. i am a super nerd!!! i program batch coding and hacking things and play with knex 22/7(22 hours because there has to be time to hack and do batch)
Baron A (author)dsman1952762008-02-25
What about sleep? { : D
dsman195276 (author)Baron A2008-02-25
do you just go through my comments and tell me anything i do wrong? lol umm... i sleep walk but insted of walking around i play with knex. lol.
awsome (author)dsman1952762008-04-15
lol. btw...have you heard of something called pokesav?
dsman195276 (author)awsome2008-04-15
yea, what about it?
I use it, It works reaqlly well if you know what your doin. you should try it Dsman.
i have used it, but i don't need it. it just takes me longer because all it does is edit the codes for you. as in, the first line of code is programed into the pokesav program, what you enter just gets converted to hexdecimal and put into the code. i can do that a lot faster if i do it by hand instead of typing it in like that.
It was supposed to be a joke.... Calm down lol.
i know it was a joke. i was just suprised that you see so many of my comments.
ojochris (author)dsman1952762008-02-24
Where is part 2?
i am still making it. thats y the name of this is part one. part two will be editing and finding the first part of simple codes(probely). o and hows this for a ad for this instructable?
HOw did you do that? I'm stuck on the ******* last shroom princess and I keep dying!!!
ojochris (author)dsman1952762008-03-02
Is that the mario Bros Stuck in time one?
dsman195276 (author)ojochris2008-03-16
no, mario & luigi super star saga(but mario & luigi partners in time was the sequal).
and be warned, this is like a walk in the park compared to part two.
chicken woman (author)2008-02-18
What is Missingno and how do u gettit?
missingno. was a test pokemon in pokemon blue and red(it was removed by the time yellow verson came out) it allong with the other glitch pokemon can be found with out a action replay. i just put that picture because it is cool. you can get by doing the following: first you need a pokemon the know serf and fly and beten the game at least up to cinibar island first: go to the second town in the game and talk to the guy that stoped you at the begginning of the game. he will ask you if you are in a hurry and say no. \ he will teach you how to cheach a pokemon after that immetely fly to cinnibar island and serf the right side of the island(were it is half water and half land) you will find pokemon over level 100and some times you find missingno.(note the pokemon you enconter completly depends on your name) the missingno. i encountered is a kupotops fussle missigno. yours might be the regular missingno. wich is a glitch pokemon. cheaching missingno. will not effect your game in any really bad way (if you look at his stats your battles will be glitchy, just look at a normal pokemons stats to make it normal.)(the one thing you cant change is it will glitch up your hallafame(who cares bout that?))) thought cheching missingno is rummored to erase your game(i have done it millions of thimes with no game erasing) the big thing missingno. does does not need you to chech it. when you see missingno. the item in your sixth slot will go to its max(128 of your 6th item is good(the first number in your 6th item slot is a glitch block). this can give you unlimited proteans, rarecandys, and nuggets. i could go on and on about what i know about missingno. but you would get so borred so i wont. i hope this helps!
So...u only get it in Red\Blue
yes that is true. it was a test pokemon that they never thought to remove from the game. in pokemon diamond / pairl you can get a pokemon similer to missingno. by doing the following(note you need a action replay)
first you need to activate the walk through walls cheat and the infanite life cheat
then go straight to the pokemon lab with out going to the lake to get your pokemon.
the scientist will give you a pokemon named "-----"(you can nickname him missingno. if you want)
then go straight to the first gym with out geting into any battles!!!
go straight to the gym leader and battel him.
you will see a weard pokemon popup for you pokemon. if you do not have a health cheat the pokemon will die intently. it knows no moves so all you can use is struggle and it is at level zero.
why this works:
the pokemon that poped up is called a place holder(not actuly a pokemon). this is in the game data because the game needed somthing to use as a pokemon.
what is happining in your game is this
you got into a forced battle(the game forces you to battle(this is not like a traner battle)). the game never relises that you have no pokemon. all the game looks at at the beginning of the game is the hex number of the pokemon. there is no pokemon there so the hex number is automaticaly set to zero(zero is the hex number of the place holder). the place holder has nothing(no moves ,no levels and no hp(thats what the health cheat is for))
is it possible to do this just to see the pokemon, and then load back on to your old file... without losing your data.
yea
About This Instructable
38,289views
11favorites
License:
Bio: Just your average K'Nexer/Programer/Nintendo DS fanatic. Any questions you would like to ask about any of the above? Send me a PM ... More »
More by dsman195276:K'NEX Pinball Machine!K'NEX Rail Car and TrackNERF Sniper Pistol!
Add instructable to:
