3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to get music from ALMOST ANY( haha) website ( as long as you can hear it you can get it... ok fine if it is embeded in flash you might not be able to) EDITED!!!!! added info
if you ever go to a website and it plays a song that you like and want it then here is the instructable for you
not my fault if you mess something up ( only way it will happen is if you start deleting stuff for no reason)
ive been able to get music fom myspace, music.download.com, friendstation.com, there are alot of places... i have been looking for ringtones on all of those online places that send them to your phone and they all apear in the file described.
I FOUND HOW TO GET MOZILA TEMPORARY FILES!!!
C:\Documents and Settings\(your username here)\Local Settings\Application Data\Mozilla\Firefox\Profiles
ok here is an awesome program that will help you get anything you want from anywhere
http://www.tweakxp.com/article39044.aspx
Step 1Open your "MY DOCUMENTS" folder
open your \"MY DOCUMENTS\" folder
open your "my documents" folder and do what the below picture explains... click that button
after that click the "tools" menu in the menu bar and click "folder options"
47 comments
1-40 of 47next »
Jun 25, 2008. 1:32 PMlopez8675 says:
couldnt you just get a cable that has a 3.5mm end on each side(from external speakers) and put it in the speaker out to mic in and record?
Feb 9, 2009. 2:27 PMChicken2209 says:
even still, the recording would come out a little scratchy because even though the metals used in the cables are good conductors, they arent perfect. Several programs like audacity can record directly off the computer without cables
Feb 9, 2009. 5:17 PMlopez8675 says:
o ok. personally i haven't tried this because i heard that if you plug it into the wrong port you could fry your sound card.
Feb 9, 2009. 5:20 PMChicken2209 says:
Oh, I forgot. I wouldn't do that because on the microphone jack gets electricity from the computer. So essential something like this has a possibility of happening. I wouldn't plug anything into the microphone slot that has its own current unless it says on the box that it can
Nov 3, 2008. 9:19 PMlgn88 says:
Props for all your hard work, but can I just say that if you use AUDIOGRABBER you can just record ANY and ALL sounds coming from your pc, whether they be from videos, flash, streaming music, in game, etc etc etc.. and all it takes is one simple click
Mar 10, 2008. 5:28 PMPumpkin$ says:
I probably sound like a total noob right now.... but can you explain to me again what to do with the various items in temp. files? the instructable didn't help me there. what I mean is can I take the vids and drop them into my videos on windows media player?
Jul 26, 2007. 11:33 AMdchall8 says:
With Firefox I get file names like 63B98C0Fd01 and no file extension. Yes, my file extensions normally show. The file size is a give-away as to which files are which, but that doesn't tell me if the file is an .mp3 or a .wma. I tried opening what apparently is a .wma file with Windows Media Player but it did not play it. Audacity will not play a .wma file directly.
Sep 15, 2007. 4:49 PMVoxel says:
i have done this before. you open that with firefox, and then it asks you what you want to open it with, then you chose WMP
Jun 12, 2007. 10:10 AMMace42 says:
does this work in vista?
Jun 13, 2007. 11:29 AMMace42 says:
It would be in a slightly different directory.
Jun 13, 2007. 11:30 AMMace42 says:
(i think)
Jun 1, 2007. 3:48 PMOpieone says:
This is great thx. Anyone know where i can get free videos so i can burn them?
Jun 6, 2007. 10:58 AMtashe32 says:
can you use Napster?
May 31, 2007. 2:12 PMNocturne says:
For some reason, when I tried it, in the Local Settings folder, I only get Application Data, Apps, and Temp (not temporary internet files- just "Temp") I've checked all three, and neither of them seem to have any sort of music files (I was listening to Pandora). I have followed your instructions exactly, ( and have retried several times), but no results. Do you know what might be wrong?
May 31, 2007. 11:13 PMrecneps says:
Just use stereo mix (or mono mix) all it does is record data straight from your sound card. Just go to a free program like audacity, choose stereo mix (or mono) and record away. if your program doesnt have the option to choose, just open sound properties (double click the icon on taskbar) and go options -> properties then click recording, check everything below and click OK choose stereo (or mono) mix. Then go to your recording program and click record. Play the audio that you want to save, and when its finished, go to the program and click stop. Trim the parts at start/end and voila.
May 31, 2007. 11:14 PMrecneps says:
oh and sound quality should be lossless as long as you're not using a crappy program like sound recorder. (if it sounds good from your speakers it should record just as well.)
May 31, 2007. 2:28 PMNocturne says:
Firefox. I am trying it now with IE.
May 31, 2007. 2:50 PMNocturne says:
No luck :(
May 28, 2007. 9:57 AMgyromild says:
Great instructable. I've dug into the temp files before, but to get youtube clips, never done it with audios though. If you are in need of a little more adventure, you can try this.. All sound that comes out of the PC soundcard can be captured. Be it from flash, clips, website, movie dvd, vcd, webradio, podcast, etc. Try loopbacking the soundcard output back into the input. Taking the input eternally, you can even capture audio from radio or even tv shows if you want. The quality can be slightly lossy. But with a good software, the captured audio can be edited, cleaned and converted to virtually any format (mp3 and so on). I've used these methods to get audios from the web before, even converted some of my old audio cassettes to mp3s.
May 27, 2007. 6:00 AMDeathbrush says:
Well, if you want a really easy way to check data saved to your system, even just stored in memory just put this into your address bar. about:cache This will give you access to your disk cache and memory and to my knowledge works on almost any windows browser. Though a lot of music sites like soundclick and such that simply add the nocache command to data so it's not stored in such an easy to access fashion, but it's pretty easy to have your browser locally cache all data to a file, this will bypass the nocache security fix. I won't go into this but it's relatively easy to find information on how to do this. Side note, first post on here, hope I can contribute something useful.
May 24, 2007. 4:11 PMTheCheese9921 says:
my temporary internet file is empty, I deleted everything b/c there was a lot of crap, then I went to http://www.purevolume.com and looked at some sites, I hit the refresh in the folder and there is still nothing.
May 25, 2007. 3:24 PMTheCheese9921 says:
thanks yea, you have to use IE : ( Does anyone know where Firefox puts it temporary Files?
May 25, 2007. 8:23 PMTheCheese9921 says:
sweet thanks
May 24, 2007. 9:42 PMCrash2108 says:
I'm pretty sure it only works when you use Internet Explorer. Other browsers don't use the stock Windows directory for temp internet files.
May 24, 2007. 9:28 PMgarrettmikesmith says:
you might have to listen to the entire song.
May 26, 2007. 12:10 AMThinktank says:
For people looking to get music from flash files. 2 words. Flash Decompiler I am done.
May 25, 2007. 5:55 AMazog says:
The title is a little misleading. This won't work for the majority of streaming sites, like rhapsody (encoded in flash) or shoutcast.
May 25, 2007. 8:30 AMazog says:
You can use something called streamripper to capture shoutcast. Thank you for addressing my comment, but it still stands - your title says "any", which is emphasized (in caps), but it only works if the site has an embedded mp3 in the URL. And there are ways to get embedded flash, too, but that's for another day and discussion :-/
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pufftmd2389
