3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to get past your school's blocker
Step 5Another replacement
another replacement
this is a good replacement for translation proxies (because they suck), and because it's so much easier. You have to be using windows by the way.
goto command prompt.
type ping "the name of the website"
take down the ip address
when on the web, type the ip of your website in the http toolbar, then it'll go to that website. but it doesn't really go anywhere. but you can use it to go to the tunnel sites
8 comments
Dec 14, 2011. 9:00 AMJaron W Gneiting says:
Yo fran man. You can always open command prompt no matter what. don't matter what they do. open a text document. type "start" and then save as "command prompt.bat" and watch my brain go to work. I know these things. i've hacked before and the try every way to block me out but the can't block notepad or .bat files or else they won't be able to run simple programs like word. one of the main reasons they have computers in schools
Apr 22, 2012. 8:50 PMI_Know_Everything! says:
If you know so much then why dont you tell us how to actually hack instead of how open command prompt which anyone knows how to do!
Feb 2, 2012. 2:47 PMPinkie Pie says:
FYI they can block them. Its called Group policies. It allows them to set particular files or directories to run .exe or .bat files and others to not run them. They can also disable command prompt. They have almost complete control. But their proxies cannnot block your own computer. And no proxy or firewall has managed to block Hamachi yet.
May 25, 2010. 5:59 PMsparx01 says:
doesn't work. still blocked. :(
Apr 12, 2010. 1:19 PMSirFlyer says:
wow, good idea, i never thought of that one.
Mar 6, 2009. 10:47 AMskullkrusher says:
what does it mean go to command prompt
Mar 13, 2009. 7:33 AMDevin.Major says:
Go to the command Prompt means to go to the black screen that you type commands into. Still not sure, go to run on start menu and type in command prompt or command.com, you'll recognize it wen u see it
Jan 10, 2008. 1:52 PMfranman says:
at my school they block the command prompt the best way to do it is get a long list of proxies and click on all of them and see which ones work
Mar 29, 2008. 12:02 PMthrongar says:
if command prompt is blocked then all you have to do is go to start-run then type command.com. then press enter. that should work
Jan 15, 2009. 5:24 AMStarGater93 says:
or you could use a batch (bat) file with "ping ADDRESS" (and i included a pause at the end just incase i got 1000 command prompt windows... it happened to me before (dont know y) and i dont want it to happen again) so just double click on it and it will give u the ip... then kill it afterwords... (unfourtently it didnt work for my site chat... damn websence -_-)
Dec 30, 2007. 1:30 AMizzyburkett1 says:
you don't need to use windows to ping sites. open network utilities in mac operating systems and select ping
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:thefirstgaruga
