loading
Step 2: unwind the tape
This is the hardest part as well as the most boring!
The tape usually starts where the two wires go in or sometimes about 6 inches down.
You may want to upload a YouTube video before you start because its going to take a long time!
If you want to keep the tape you could wrap it around a pencil or something.
use the scissors to cut excess tape and the two main wires but DONT cut the magnet wire!!!
Im concerned about the lethal voltages that are stored in these tubes for a period of time after they are turned off.Do you know how long you would have to wait before tinkering with one of these tubes ? <br>And also could you do the same with an old computer tube type monitor? <br>Thanks
Length of wait for safety is INFINITE.<br> ALWAYS use standard tube discharge procedures. I<br> f you didn't just discharge the tube yourself, it's not safe.<br> The longest I've seen a tube hold a measurable charge was just under one year...larger tubes may hold for longer.&nbsp;I dunno, and am not gonna risk it.<br> <br> Dischargiong is SIMPLE, and safe, when done properly. no reason to avoid it.<br> <br> <br> As to the&nbsp;computer CRT question... YES.<br> Some REALLY old monitors don't have the coils, but pretty much anything with a VGA connector will. Same tube discharge rules apply to Monitors as to tv's.&nbsp;
<p>How do you Discharge an old TV Set properly?</p>
There can be some subtle differences in technique, but basically, get a flat bladed screwdriver, and a length of heavy gauge wire with aligator clips on both ends. Clip one end onto the screwdriver, and the other to ground. Carefully poke around under the rubber cap with the tip of the screwdriver until you hear the ZZzzzzttttpppop sound.
All guns are always loaded and all capacitors are always charged. Rules to live long by.
do you have scrap
I have lots of scrap <br>
.&nbsp; +1.<br> .&nbsp; Waiting for the charge to dissipate is not a good idea - it takes &quot;forever&quot; and doesn't always work well. Follow the procedures to safely discharge the tube.<br>
Again, this instructable has nothing to do with taking apart TVs. I dont know how long its takes, probably a few months. Any CRT display screen will have at least one.
<p>Removing the eenamel, well, it is tough. </p><p>Acetone might work. Some enamels were made VERY tough to avoid shorts <br>in coils,so it's purposely VERY hard to remove. Fire removal gets you <br>much less at the scrap yard. Perhaps smelt it thereby cleaning the ash <br>and rendering better grade bright copper... Be prepared for a high <br>propane bill, and a costly smelter, unless you build your own. Heavy <br>fireproof gloves, tongs, a crucible, and some other safety equipment is <br>in order.</p>
<p>Awsome! I finished removing all of the copper wire from my television last night. I even had the patience to unwind all of the wire from the deflection coil because I needed the ferrite core to make a giant joule thief. I found that the wire from the coil was more useful for winding magnets, inductors, and transformers because there were only a few places where I had to solder the wire. I have been thinking about soldering all the individual strands of wire from the cable together, but that sounds more like busywork than a project, especially when you consider the fact that I already have a huge roll of 24 AWG wire just waiting to be used. </p>
<p>Can &quot; the black cable&quot; be used for anything?.I mean it looks like a base for metaldetector or?</p><p>it is a very long wire with 1 outlets,same coil.</p><p>i tried google but didnt find anything it can be used for.</p>
<p>wow!</p><p>I recently took apart a CRT and found that weird thing wrapped in tape... I did not know it was full of enameled wire! I will have to rip it open sometime! Thanks!</p><p>Don't forget the CRT deflection coils; they have lots of enameled wire too.</p>
<p>Wew I love this guy and this instructable.</p>
<p>Thanks, did it!</p>
<p>Yes, but how do you REMOVE the enamel from the wire? it makes the wire worth more to scrap. I've tried lye, denatured alcohol, varnish remover, and other things but nothing works - and some like the lye ate the wire. :(</p>
<p>fire works fine</p>
<p>you can always break the plastic spool with a sledge hammer or whatever you choose and remove the cooper that way vs spending time unraveling .... right?</p>
Thanks for posting this. I tried to wind the wire faster by chucking the spool in a drill, which worked great until the whole thing turned into a tangled mess :P
Thank you for this. However, it kills me to know that I've thrown away so much free wire!
<br> Yes, it is a good source.<br> <br> L<br>
did you already have that or did you find it out from this?
<br> I did it months ago, but got tired of trying to wind it <em>neatly</em> on a VHS reel.<br> <br> L<br>
oh, ok. well its better than buying it!
how much
do you have junck
You omit the <a href="http://www.google.com.ar/images?q=yugo%20%2Btv&oe=utf-8&rls=org.mozilla:es-AR:official&client=firefox-a&um=1&ie=UTF-8&source=og&sa=N&hl=es&tab=wi&biw=1045&bih=483">joke (spanish yugo)</a>. It is even a better source of copper wire.&nbsp;<br>
yes, i know but this isnt about that.
bout wat <br>
From www.todoexpertos.com:
i want some
i want some
you &quot;Raped&quot; it around the spool? isn't that a felony?
lol
you fine
watch your spelling
ew u nasty make
only if you get caught
haha lol
i blame google spell check! lol
I think that's sort of like the old &quot;over a barrel&quot; proverb, but on a much smaller scale...
nice. the spelling error was no big deal. I must have just been in a trolling mood that day. great instructable!
hey guys heres a way to earn money for all that coppor wire ok take all of it to your local phone copany and they il give u like 20 bucks a pound its fantastic!!
wow i have a box full of scrap copper but i dont know where to take it, thanks!
all thanks for my science teacher
what up
can i have it
i will tack it call 6513997835
About This Instructable
172,972views
111favorites
License:
More by Jimmy Proton:Make a 240V MOT high voltage power supply with 120V transformers awesome MOT power supply My vacuum tube collection
Add instructable to:
