loading
Step 2: Quick freedom!!!
NOTE!!! This is for 2.2.1 Not 3.0.
NOTE!!! you still need the C++ redistributable file. i will put it as a download at the bottom of this page.
you now do not need any of the other steps. quick freedom does it all. if you do not trust gui applications with your precious pod, i will leave the other steps up anyway.
I have re-ordered the steps to change priority. There is now a gui called quick freedom that Berky93 was kind enough to tell me about, and report its success. You can go to Quick freedom's homepage to download the newest release. Quick freedom supports custom boot logos, whereas my original instructable did not. I edited my favorite of the included 8 png files to include the words, "Cyle's Ipod" above the logo and"Jailbroken" below. This time i will fully document the jailbreak, because i will be doing it also! There will be a youtube video along with words.
The first time you start quick freedom it will check for the 2.2.1 original firmware file. if it can not locate the file for you it will give you the option to either browse to the file of download it through quickfreedom. it will also check for libusb. on windows xp and vista 32 bit it is as easy as clicking install libusb to get it installed, but on vista 64 bit, which i just happen to have, it is really hard. i am not going to cover vista 64 bit. any way, click next. Now you have the option to install installer, and the custom boot logo. you can choose to put installer in, but you dont have to. cydia is automatically installed. click add custom boot logo to see if there are any you like. You can also pick a new recovery logo. this is the connect to itunes logo you saw when you first bought your ipod. you can also make your own, just take the 320 x 480 pixels. anything that is not artwork must be transparent, so remember that. make sure you check custom boot logo if you want it, then click "create firmware". after that is done, you will have a jailbroken firmware ipsw file on your desktop. click next. put your ipod in DFU mode. if you dont know how, you can click the dfu instructions, or just do this: hold both buttons on the ipod down for 9 seconds, and then let go of the top power button. continue holding the bottom home button for another 9 seconds. down in the corner of quick freedom it will say dfu mode if you did it right. if not, try again. press start pre jailbreaking. if you dont do this, itunes will give you an error when trying to restore. after it is completed, you can close out of quick freedom. the next step is just telling you how to restore, but you've got me for that : ) open up itunes. it will complain about the ipod being in recovery mode, but just click ok. you are going to click restore, BUT MAKE SURE YOU HOLD DOWN SHIFT!!! if you dont all that work just went to waste. a file browser window will pop up, and you need to navigate to your desktop. once there, click on the jailbroken firmware file. the ipod will begin to restore. once it is done, so are you!! you can go to the step before the last step for some cool stuff : )
ROBOTS199's DFU MODE TRICK: It can be hard to get into DFU mode with only one pair of hands to do three jobs. I had a lot of trouble at first doing all three tasks at once. To solve this problem, have a second person connect the cable to the iPod , while you hold the power and home button.
EDIT:::: There is now a new version of the quick freedom program. it allows you to also change the "connect to itunes" logo. You can also now change your boot logo(s) without having to do a full restore. Only do this with an ipod touch 2nd gen that is already jailbroken. When you open up quick freedom, click change logo. pick your logos and create your firmware. Make sure you check the "already jailbroken" box. Put your ipod in recovery mode. this can usually be done by clicking the recovery mode button, but if you have to do it manually then follow the following directions: hold the bottom home button and plug your ipod into your computer. continue holding the home button for 10 seconds, and then the connect to itunes recovery logo will popup. in itunes hold shift and click restore and browse to the "custom nor.ipsw" file which will be located on your desktop. This supposedly will only change the boot logos, and nothing else. I dont know if it will work that way yet, but i will get back to you as soon as i find out, which will be pretty soon 'cus im really digging that bottom-left recovery logo. i may even customize it with some kind of "It's all your fault!!" text or something... heh.. hehe. Thats actually a pretty funny thing. You break your ipod and get scolded. Anyway, have fun.
ok, so on quickfreedom when you browse the file i can only find a zipper file with two files, firmware and somthing else any help would be appreciated <br>
I'll take broken ipods
How do you change the font on your computer?
I'm on windows vista, this wont be the same for xp but it probably will for 7. I right click the desktop and personalize, then &quot;Windows Color and Appearance&quot; then &quot;Open classic appearance properties..&quot; then click &quot;Advanced&quot;. Its pretty straightforward from there.
An easier arguably more safer way to jailbreak that works on any ipod touch is here&nbsp;<a href="http://www.jonys.info/2010/02/how-to-jailbreak-your-ipod/" rel="nofollow">www.jonys.info/2010/02/how-to-jailbreak-your-ipod/</a>
So my itouch 2G screen didn&rsquo;t turn white. But Itunes recognize it and it is in DFU mode&hellip;I try unplug and plug it back in.But it wouldn&rsquo;t work.. what can I do?!? Please help!!<br />
You need to try holding down both buttons to see if it resets. if it doesnt then put it in dfu mode and restore in itunes then redo the process. NEVER unplug it unless you see the springboard or the tutorial says to.<br />
can't seem to find where my 3.0 update resides on the HD. Only empty folder in iTunes music folder. My iPod is updated however.
Enable Hidden Folders
i need help i did all the steps but i still dont see cydia on my ipod touch plz help.
That means you didnt hold shift when you clicked restore. If you did hold shift and you did click restore but you messed up on one of the other steps you would have gotten an error in itunes. if you held shift and did everything right you would have hacked firmware AND cydia. since you got everything set up it should take you less than 30 minutes to rejailbreak. all you need to do is put the ipod in dfu mode and do the prejailbreak again, then hold shift and click restore in itunes and find the jailbroken ipsw file than quick freedom made.
i meant to say "THAT quick freedom made." there in the last sentence.
ok i went through all the steps and now im in itunes and its has said restoring ipod software for about 45 min now what should i do?
it is working i think. if there was a little status bar on the ipod that is good. It shouldnt take that much longer unless its a really old computer. i have a 2005 desktop and it takes me about 50 minutes to do the whole process, and 35 or 40 of it is restoring.
Hello, i have run into a problem and im not quite sure what to do :/... I have gotten to the patching stage but i keep getting a message saying that 7-zip standalone console has encountered a problem and needs to close... It will not patch the firmware... What do i do??? Thanks in advance
A.C.E did you add the 3.0 jailbreak part before june 21st? someone made ANOTHER redsn0w tutorial.
yeah, it was like the 15th or something lol.. COPIERS!!!!!
ill go tell him/her
well im back home now and i think i am going to update the 3.0 page on how to do it on mac.
Hey im running Windows XP and i have everything i need got to the custom firmware part it finished creating BUT when patching it it gets to finalizing patch and it just stays there ive slept for like 8 hrs i wake up and it still is stuck on "Finalizing Firmware." Oh and i have the newest version of QuickFreedom. Can you please help.
are you trying to jailbreak 3.0? You have to use the new release of redsnow on the 3.0 page.
Thanks A.C.E for adding in the new redsn0w release, i am on vacation and i was busy.
Now i watch the video. so you have a annoying little brother? feel lucky! i have two sisters!
I put my iPod in DFU mode but then i accidentally pressed cancel when itunes came up. Now my iPod won't turn back on. what do i do? please help
if you did the pre-jailbreak then you will have to put it in dfu mode again and then restore it. if you did not do the pre-jailbreak, hold both buttons down and eventually you will see the apple. release them then and it will power on as usual.
Help Me! i download the firware but when i go to Quickfreedom it cant find the firmware, and when i browse i cant find the ipsw file
Can i film it? No that is not neccasary. Lol
ok this isn't working. I go to create the custom firmware, and it says its starting to create it, but a window comes up and says "error! error creating firmware" and the log still says its creating it! i downloaded libusb and the c++ file, but nothings working! im using vista, so could that have something to do with it? help please!
A.C.E it was me who added pics, i just forgot to put i added them.
OMG I've done everything and now I just need to create the custom IPSW file. Except when I go to make the file in quickfreedom the change log says "Error - Could not load IPSW". I have no idea why this is happening.
Did you install the C++ redistro from step 2 and renamed it and r u using vista? if so make sure you set up libusb correctly.
Hmm. I set up the C++ file correctly and the libusb file. I'm using 64-bit Vista. For now I'll double check the libusb file cause I'm not 100% sure about that one.
libusb jacked up my usb ports hen i didnt install it just right. if you open quick freedom with your ipod plugged in and it knows what state the ipod is in (indicated in the lower right corner) then it is installed good.
On the gpsphone can you design your own theme for it if so is it hard or time consuming?
if you know how to make good images in photoshop or gimp then its easy. just get one of the default themes that you hate, and replace the images.
well for instance the iglasssol theme, for bowling for instance. how did the maker make the pins so good? it looks like 3 pins standing up. there are different color shades and everything is shiny and reflective. i guess im just a noob with gimp, i can only use simple filters and transparency and make banners and stuff
it takes gradients a steady hand and lots of training. Also skill
ok yeah
I was wondering if you knew how to change the text that says "iPod" on a jailborken iTouch (I have installed and cydia). Thanks, Posted from my iPod
yeah search for an app in cydia that will either be called mim or make it mine
Thanks so much! I gave a 5 star rating and subscribed. Typing in "mine" worked... Posted from my iPod...
ok. to reset it back to ipod or back to the time dont type anything and press the button to change. im telling you this because if you need to take the ipod to an apple store or somewhere to repair it, a normal restore will not get rid of a changed banner or ipod logo. you need to change it back with mim before you restore, or else they will know it was jailbroken and not fix it. thanks for the 5 star
Nice! I just got my iTouch today and i will be jailbreaking A.S.A.P 5* and faved. :D<br/>
ok thanks for the 5 star, hope it turns out well
if u get an ipod mic can you use the phone?
i downloaded everything i needed to jailbreak my ipod from quick freedom, and i got to the second step create custom firmware. it has been at 32 percent for hours, and this is what my log says: 1:32:08 PM Select options above and click Create Firmware 1:32:44 PM Starting Firmware Creation - Created by Dancool999, credit to planetbeing for xPwn 1:32:44 PM This process may take 5-10 minutes to complete. 1:38:01 PM Starting firmware creation... 1:41:17 PM Now creating, please wait... what should i do?
scroll down on the quick freedom page untill you see vcredist_x86.exe download run and install. restart your computer (reccomended but who cares) and open quick freedom.
oh and im pretty busy so if you or anyone that can help at all please email me at theshow1974@aim.com
i have a annoying problem. on the bottom of my ipods screen i see this little yellow bar. its so annoying how do i get rid of it
fixed it was the dock app
About This Instructable
24,772views
20favorites
License:
More by A.C.E.:How to virtually mount a disc file How to jailbreak (untethered) 3.0 and 2.2.1 How to Inject Custom Songs into Guitar Hero III or Aerosmith on any Wii
Add instructable to:
