How to Kiss
How to Kiss
This is an instructable on how to kiss. Kissing can be a hard thing to do until you get comfortable doing it, and while nothing can fully prepare you for a kiss, this how-to will explain some of the basics of kissing a partner and explore some simple kissing do's and don't's.
Note: I am by no means a kissing expert. The information in this instructable is based upon experience and some simple research on the subject.
Let's get started with just a simple kiss.
Step 1Pre Kiss
Pre Kiss
The lead up to the kiss can actually be the most difficult part of kissing. Figuring out whether your partner is ready to kiss you or not can be a challenge of its own.
If you see one or a combination of these indicators, there is a good chance that your partner is thinking about kissing you.
  • eyes become soft and heavy
  • eye contact is made and sustained
  • head turns slightly
  • lips are licked or bitten
  • your partner makes physical contact with you beyond what seems appropriate for normal conversation (e.g. he or she brushes your hand, touches you on the shoulder or leg, or fidgets with an accessory)
  • easy conversation comes to a stop, but eye contact is not broken
  • your partner smiles in conjunction with any of the above behaviors
To give your partner the cue that you wish to kiss him or her, you can try one or a combination of these things.
  • soften your gaze by relaxing the muscles around your eyes, somewhat like smiling but without engaging your mouth
  • smile often, though
  • make eye contact and allow it to linger for a few moments longer than you normally would
  • find ways to subtly (but respectfully) touch your partner
If you think you are picking up some of these signs, but are still unsure if the person wants to be kissed then there is nothing wrong with just simply asking your partner if a kiss would be all right. Granted it breaks the mood a bit, and sensing the magic is always nicer than asking if it's there, but better to be sure your partner is on board for the kiss otherwise you might be heading for an embarrassing situation.
If you've assessed the situation, and it seems probable that a kiss is imminent, the next things to think about are timing and approach. The key to nailing the pre kiss is matching your partner's speed and intensity. The kiss is the first opportunity to physically connect with your partner, and so you want to meet him or her halfway.
Here are some steps you could follow as you go in for the kiss. Keep in mind that the kiss you share with someone is as unique as your relationship with that person, so follow your instincts and use the following as a rough guideline.
1. Establish a physical connection by placing your hands on your partner's body. Placement depends on the dynamic between you, you can softly touch the face, the back of the neck or the shoulders. Be gentle with your touch if this is the first contact you are making. Stay away from "high risk" zones on your partners body, as you just want to indicate that you are interested in kissing them, not give them a full body search.
2. Establish and maintain eye contact from this point on. The eyes are often a clear indicator if someone wants to be kissed, or is thinking about kissing you. Try to look at your partner with a deep, yet soft gaze. Use your eyes to send them a message that shows how you feel for your partner, e.g., "I care for you, I am on fire when I look at you, I want to kiss you."
3. As you lean in, you may want to tilt your body and head to accommodate your partner's positioning. One partner will have to make room for the other, or both partners can just slightly tilt heads in opposite directions. Basically you are just trying to avoid a nose collision as you get closer, so just pick a side to turn to and don't give it too much thought.
4. Gauge how quickly your partner is leaning in and try to meet at the halfway point between you, so neither person is overextended. Over/under extension can make one person feel like they are not getting met and are either too aggressive, or not engaged enough.
If you have come this far with your partner chances are you are going to kiss, or you have misread the entire situation and they are just leaning in to look at something stuck in your teeth.
If the first is true, then read on because it's time to pucker up and get on with THE KISS.
1601 comments
1-40 of 1601next »
Feb 8, 2012. 7:27 PMpjkona21 says:
okay so my boyfriend have been dating for 4 months almost 5 and we dont talk that much in person he is really shy so am i.....we both want to kiss yet its awkward and i feel like he is losing interest
Feb 6, 2012. 6:36 AMjade_2 says:
okay, me and my boyfriend are ready to have our first kiss. we are both nervous and we've been dating for 5 months. he says he's gonna do it but he never does..what do i do? i need helpppp!
May 19, 2007. 12:09 AMbrianj says:
just smudged up my screen practicing. ok no time to waste. back to work.
Feb 5, 2012. 6:44 PMFlipperstriper says:
LOL!!! ME TOO!!!!
Feb 5, 2012. 6:42 PMFlipperstriper says:
And one more DON"T
Try not to burp or sneeze in your partner's mouth, my boyfriend sneezed in my mouth and it was NASTY!!!!! So, just a little heads up to make sure your sneezes, burps, and any other thing that might be repelling to your partner is out of your system. And if you feel something coming, definitely back away!!! I promise they will be grateful.
Jan 27, 2012. 5:38 AMjiyeon94 says:
okay just for an update.,my guy is more of an aggressive type of person and since the day we kissed there isn't a day we won't Like make-out or whatever.,umm I'm think it's more we got comfortabLe with it...
most of the time he's the one to do the 1st move 'cause...heLLo. . .it's really awkward for girls to do it.,
GUYS if you're on a date and if you Like want to kiss..
consider EVERYTHING first before doing the move.,
you don't want rejections or anything...
I think its better if. . .you Like hold hand or cuddLe or something before doing any kissing.,just to get comfy^^
and not get awkward and bye bye Girl I first kissed.,
umm soo there^^
KIDS DON'T RUSH.,IT WILL COME..
sooner or Later.,haha :')
just in a matter of time~~~
>> purposely used the word KIDS
Jan 22, 2012. 5:23 PMviolet_skies43 says:
My boyfriend and I have already (kinda awkwardly) talked about how we both are totally cool with kissing and are just really nervous about it since finding alone time is hard. But goddammit it drives me crazy to look into his eyes and then someone walks in the room
Jan 26, 2012. 10:38 PMmadame2068 says:
you just have to find the write moment. i have a bf and weve dated 4 like a month and a half and my parents still dont know that im dating him, i want 2 kiss him and he told me he wants 2 kiss me but im 2 shy and i dont think hes ever had his first kiss even though he says so, what should i do?
Jan 18, 2012. 7:53 PMJozef_14 says:
Alright so, I've got these girls that like me and I like one of them too. And we always start these conversations but they never seem to last?
Jan 26, 2012. 10:11 PMmadame2068 says:
well ask the girl you like out and see if you 2 hit it off if the conversation thing happens well do your best to keep going and to have fun!
Sep 10, 2010. 12:58 PMtink99 says:
omg! i want to be kissed so bad!
Nov 4, 2011. 5:42 AMDaviktion says:
Join the club! i haven't even been on a date yet. :'( 13 yrs.
Jan 26, 2012. 10:08 PMmadame2068 says:
Don't worry about it one day you will.
Nov 30, 2011. 7:35 AMjasonator001 says:
i went on a dateand kissed her but she didnt want anyone to know is that bad
Jan 26, 2012. 10:12 PMmadame2068 says:
well not really she just might not be ready 4 people 2 know yet she might be shy about it.
Nov 21, 2011. 9:17 PMatalerico says:
18 here and I'm still holding out. The sad thing? I found the right girl and I've told her how I feel, but I can't bring myself to asking her out. Gotta love that Long Unresolved Sexual Tension.
Nov 22, 2011. 12:33 PMDaviktion says:
Dude, all you need to do is ask her out. your problems will be completely resolved, as long as she likes you too. if you are a little nerd asking out a cheerleader, than maybe not, but if you're both at about the same height on the social ladder, you'll do great.
Nov 22, 2011. 1:24 PMatalerico says:
(And yes, we did still go to her Homecoming and it was amazing.)
Nov 22, 2011. 1:23 PMatalerico says:
That's not the problem. She actually asked me out a while back (to her school's Homecoming dance) and I said yes, but we're so perfect as friends that at the time I felt any more intimacy would ruin it, and I told her. I have since realized that I was wrong, but saying so would make me look like a jerk. THAT is the issue, it is something that I plan to deal with on my own.
Jan 29, 2012. 10:38 AMf5mando says:
Getting over our concern of 'looking bad' AKA 'not looking good', is the key to moving forward. Too many missed opportunities and a change of this mindset really set me free.
*When I was a youngster I never asked a girl out for fear of rejection (not looking good). I was almost out of my teens before I kissed a girl.
Nov 23, 2011. 7:51 AMDaviktion says:
okay then, good luck!
Jul 27, 2007. 4:55 PMg10tto says:
Wow. Very sweet, but at the same time kind of awkward. You two did it very maturely though, and...hey, you're both pretty hot AND kissable. Cool beans!
Jul 15, 2009. 9:12 AMPeacechick95 says:
My bf really wants to kiss. I really want to kiss him but im so scared and worried! Im scared about my parents. They r very strict. And they dont know that im dating someone. He and i hav been going out for 3weeks. But weve gone out before. Itll be 4 on tuesday. And im scared becuz im sure ill mess up and i dont how its going to happen. I just want lip to lip but idk wat he wants. Please help!!!!
Jul 15, 2009. 4:20 PMJustThatGuy says:
If it feels right then go for it! And i think youll know if the moment is right.
Jul 15, 2009. 5:29 PMPeacechick95 says:
Thanx. Hopefully i get alone time with him tomorrow or some other time.... Im just super nervous and worried that, like i mentioned before, that my parents will find out. I really care for my bf. Sometimes i cant help thinking about him being "Mr.Right." -sigh- Y r things so complicated? But all i really want to know is how to approach the kiss and how to kiss. Thxx for replying though :)
Jan 26, 2012. 10:06 PMmadame2068 says:
wow i have the same problem. its not that i dont want to kiss him or i havent kissed anyone b4, its that im to shy and iv tried everything to show him that i wanted to kiss him i even told, what should i do now?
Jul 16, 2009. 2:54 PMJustThatGuy says:
No prob
Jan 4, 2012. 7:54 AMjiyeon94 says:
lol i'm turning 18 this year and I just had my first kiss.
at first I didn't really planned to do a passionate kiss but it just turned out like that and I regret nothing..
BTW that happened last January 02, 2011
before all the scenarios happened. . .there was this cuddling,holding hands,etc.so it kinda fLt comfformtable..
and oh yeah..
things just happened, umm like I haven't kissed somebody else before but it seemed like i've kissed alot of guys..that's what my guy said. kind of awkward but his fist question when we got out of that staircase was "are you sure this is your first kiss?? where did you learned that??"
>>HONESTLY THAT WAS MY FIRST
well you're still young at the age of 13,
yeah sure I've wanted to kiss someone before..
but enjoy your youth, and there's no rule stating that a person should have kissed someone at the age of 13..
and yeah.,just wanted to share^^
>if you're gonna get one, make sure you enjoy it^^
~>no regrets :D
Jan 22, 2012. 5:26 PMviolet_skies43 says:
I love your story so much cos im in a very similar situation, im in high school and have never kissed ANYONE. im awkward HUGGING people, and my boyfriend is wicked shy and i just hope it ends well like your story did :]
Thank you for sharing!
Jan 1, 2012. 12:33 PMKaileyann says:
Im in the 7th grade and im dating an 8th grader, I have never kissed anyone before and he has kissed a lot of girls. He really wants to kiss me but im really nervous about it!! Im really scared that i will do something wrong like mess up or something! I dont want to tell him that i dont wanna kiss him because then he might think i dont like him that much. What do I do??? D:
Jan 18, 2012. 9:10 PMxiaobenben says:
first you have to try to tell him off in a nice way by saying that you are still not ready to kiss him.....
Jan 15, 2012. 12:27 PMcuttieluvu says:
if he likes u and wants to kiss u that bad then he want care if u do mess up. just try again if it is ur first kiss then he wil understand that u may mess up .
Jan 2, 2012. 5:23 PMowlcat says:
If you like him, just go for it. He'll understand that you haven't kissed before and you never know you might be really good at it naturally. You won't mess up and if you do, just laugh it off, because it'll make for a better first kiss story. :)
Jan 3, 2012. 4:12 PMKaileyann says:
Mkay! Thanx!
Jan 18, 2012. 8:48 AMKyrieNova says:
Im 17 and I feel like my first kiss was weird... because it was after the first time I had sex with my girlfriend :l
Jan 5, 2012. 2:29 PMcgrayl says:
Hi! Im 13 and in 7th grade. I know this might be to young for my first kiss but I really like this guy A LOT. I have a problem me and this guy arent really a "couple" yet we are just dating. He just asked me on a date to the movies. And he says he wants to kiss me. But I told him ive kissed somebody before and i really havent! and this guy is a big jock and im sure has kissed many girls and im afraid i will mess up or chicken out! Please HELP!(:
Jan 15, 2012. 12:23 PMcuttieluvu says:
dont worry im 14 if the guy really lkes u he wont care if you do mes up u guys can just try again till yall get it right and you r so not to young im only 14
Nov 2, 2011. 6:16 AMdani love says:
i am in the 5th grade and i met a girl and i liked her but how do i tell her that i don't want to kiss her i just want to ask to go on a date
(please help !)
Jan 9, 2012. 7:56 PMallaboutmyriches says:
just talk to her a lot and then see if she seems to like having a conversation with you. btw i'm 14 and in eighth grade but i've had 3 girlfriends
Jan 4, 2012. 1:42 AMjakobnoland says:
Okay kid do you talk to any friends of hers if not do so become friends with one of hers then open up to the friend ask her to help like advice their you go bro
1-40 of 1601next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
814
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
