3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Kiss
How to Kiss
This is an instructable on how to kiss. Kissing can be a hard thing to do until you get comfortable doing it, and while nothing can fully prepare you for a kiss, this how-to will explain some of the basics of kissing a partner and explore some simple kissing do's and don't's.
Note: I am by no means a kissing expert. The information in this instructable is based upon experience and some simple research on the subject.
Let's get started with just a simple kiss.
Step 1Pre Kiss
Pre Kiss
The lead up to the kiss can actually be the most difficult part of kissing. Figuring out whether your partner is ready to kiss you or not can be a challenge of its own.
If you see one or a combination of these indicators, there is a good chance that your partner is thinking about kissing you.
  • eyes become soft and heavy
  • eye contact is made and sustained
  • head turns slightly
  • lips are licked or bitten
  • your partner makes physical contact with you beyond what seems appropriate for normal conversation (e.g. he or she brushes your hand, touches you on the shoulder or leg, or fidgets with an accessory)
  • easy conversation comes to a stop, but eye contact is not broken
  • your partner smiles in conjunction with any of the above behaviors
To give your partner the cue that you wish to kiss him or her, you can try one or a combination of these things.
  • soften your gaze by relaxing the muscles around your eyes, somewhat like smiling but without engaging your mouth
  • smile often, though
  • make eye contact and allow it to linger for a few moments longer than you normally would
  • find ways to subtly (but respectfully) touch your partner
If you think you are picking up some of these signs, but are still unsure if the person wants to be kissed then there is nothing wrong with just simply asking your partner if a kiss would be all right. Granted it breaks the mood a bit, and sensing the magic is always nicer than asking if it's there, but better to be sure your partner is on board for the kiss otherwise you might be heading for an embarrassing situation.
If you've assessed the situation, and it seems probable that a kiss is imminent, the next things to think about are timing and approach. The key to nailing the pre kiss is matching your partner's speed and intensity. The kiss is the first opportunity to physically connect with your partner, and so you want to meet him or her halfway.
Here are some steps you could follow as you go in for the kiss. Keep in mind that the kiss you share with someone is as unique as your relationship with that person, so follow your instincts and use the following as a rough guideline.
1. Establish a physical connection by placing your hands on your partner's body. Placement depends on the dynamic between you, you can softly touch the face, the back of the neck or the shoulders. Be gentle with your touch if this is the first contact you are making. Stay away from "high risk" zones on your partners body, as you just want to indicate that you are interested in kissing them, not give them a full body search.
2. Establish and maintain eye contact from this point on. The eyes are often a clear indicator if someone wants to be kissed, or is thinking about kissing you. Try to look at your partner with a deep, yet soft gaze. Use your eyes to send them a message that shows how you feel for your partner, e.g., "I care for you, I am on fire when I look at you, I want to kiss you."
3. As you lean in, you may want to tilt your body and head to accommodate your partner's positioning. One partner will have to make room for the other, or both partners can just slightly tilt heads in opposite directions. Basically you are just trying to avoid a nose collision as you get closer, so just pick a side to turn to and don't give it too much thought.
4. Gauge how quickly your partner is leaning in and try to meet at the halfway point between you, so neither person is overextended. Over/under extension can make one person feel like they are not getting met and are either too aggressive, or not engaged enough.
If you have come this far with your partner chances are you are going to kiss, or you have misread the entire situation and they are just leaning in to look at something stuck in your teeth.
If the first is true, then read on because it's time to pucker up and get on with THE KISS.
1639 comments
1-40 of 1639next »
May 14, 2012. 1:56 PMjalawashere says:
there is two guys one i had a crush on him but .....eh he is ...........a relative of mine but now i like another guy but the other one likes me and a lot of girls including my cousin that is the sister of the other boy so i don't know what to go with which one , i am not sure of the first one although i held his hand but he is clueless and i won't wait for forever
plz help!!!!!!!!
Apr 29, 2011. 3:26 AMJustasimpleguY says:
...before i start, i won't be watchinh my spelling/grammar because im on my mobile aka nokia n97...
So... Im 13,got a solid relationship for a month now - weve been going out for around a month. Were talking like were in a relat
ionship and stuff but yet we didnt kiss. Honestly my minds all about her. Shes extremely physically attractIve. Anyways weve been in these situatioons where a kiss was like totally normal but none of us made the move... So its worrying me that im the problem. Perhaps she thinks i should go for the kiss - i dont know. Im shy too when i get the balls to kiss her to not screw something up or shell think that i want to seduce her which is completely wrong... I dont know what should i do. I just want it to work out. She said that she never kissed snyone before neither did i. So could anyone help me out please? Thanks
May 14, 2012. 1:47 PMjalawashere says:
i think u should ask her out on a romantic movie like titanic or a scary movie so u can make your move when she is scared and then look deeply into her eyes and kiss her .........
it would be the best kiss ever
p.s i am a girl and i am sorry if it is late
May 17, 2011. 3:40 PMHappyFace13 says:
you said she never has kissed either so most likely she won't care if you're good or not because she hasn't had her first kiss either. What if she's worse than you? If she knows it's your first time, things should be smooth sailing on the kissing part.
The right time is when you know she's most comfotable.If she likes Italian food, take her to an Italian restaurant and while you're waiting for your food compliment her on her outfit. Ask her what she did last night. While she's telling you, look her in the eyes and slowly move forward. She should get the hint. This could be at halftime at a sports show. But if you're at a restaurant, avoid booths. At sports games, sit near the top of the bleachers so other people don't have to watch you kiss.
Good Luck
S
May 12, 2011. 5:57 PMleilala says:
i just kissed my boyfriend day before yesterday ;) and yea. just hold hands or something and walk to someplace a bit more....empty....and it would be nice to have a wall (i had a wall to lean on and it helped so much since i was so nervous). then just kind of stare into her eyes a bit, have moment, lean in for a kiss ;) and its fine if you or her screws up. it makes it cuter :D and i know so cuz it took my boyfriend 4 tries just to try to kiss me :P hope this helped!
Nov 4, 2011. 10:53 PMImaginativeKidd says:
I'm 15 and I refuse to call my last two kisses, kisses lol
They were bad, so those kisses don't count, so in my mind, I've still never kissed a girl. Anyway, how do I keep my eyes closed when kissing? I can never bring myself to close my eyes, I'm afraid i'll miss XD
May 14, 2012. 1:33 PMjalawashere says:
well u can open your eyes until u get so close then u can't miss after that u can close your eyes
gd luck
Dec 13, 2011. 7:07 PMSamSamBunnyCat says:
Dear Kids in 5th, 6th, and 7th grade,
How do you guys even have boyfriends and girlfriends? I'm in 8th grade and I've been single forever. I have no problem with being single...
May 14, 2012. 1:08 PMjalawashere says:
well it is better when u r older so if u breakup u can accept it also i personally think dating and stuff should start at 6th grade
by the way there is someone in my grade that started dating in 3rd grade
Jan 4, 2012. 1:47 AMjakobnoland says:
well sir thats your fault i have a girl friend and her dad pulled a gun on me
Jan 8, 2012. 12:16 PMSamSamBunnyCat says:
Why?! What the hey hey?!
Dec 31, 2011. 8:39 PMcailynmarie97 says:
amen, hallelujah sister! ;) i am in 8th grade and i have had my first kiss and i have dated people before but all the guys in my grade are jerks... that is 29 guys (small school)! THEY ALL SUCK! :D so all you little kids out there... keep your hopes up! 999,999 times out of a million your not going to marry any of the kids you have crushes on in grade school! :) thank god for that statistic!
Jan 2, 2012. 6:01 PMSamSamBunnyCat says:
And, yeah. It ain't like you're gonna marry any of them. It isn't even really a relationship at our age; actually, it's just like dating. Like, really. You can't be in a serious relationship and truly love someone in middle school.
Jan 15, 2012. 12:18 PMcuttieluvu says:
thats a lie u can to if u r like 13 or more as long as u r not really really young so yes! you can not trying to be rude
Jan 17, 2012. 4:05 PMSamSamBunnyCat says:
Well, I mean, you can be in a serious relationship but not like a "Oh, I love you. Let's get married and have kids and be together until we die." kinda think. And I know you weren't trying to be rude. Everyone has their own preferences and opinions.(=
Jan 15, 2012. 5:03 PMcailynmarie97 says:
no honestly you wont love them. trust me. apperently you havent ever felt love.
Jan 5, 2012. 6:21 PMDblax says:
I wouldn't be so sure about not being able to be in love in middle school, friend. I feel like I'm in total love with my girl. I told her a we're going out. So I feel deeply in love. Gonna try and kiss her soon. :D
Jan 8, 2012. 12:15 PMSamSamBunnyCat says:
How old are you?
Jan 9, 2012. 8:10 PMDblax says:
15. And I wasn't talking about total marriage but more of just a long lasting thing.
Jan 11, 2012. 7:00 PMSamSamBunnyCat says:
Oh, yeah. In that case, go for it! Like a long lasting thing (like a year or two at least) instead of like a month I guess you could call love.
Jan 8, 2012. 12:12 PMSamSamBunnyCat says:
No offense, but I highly doubt you two will marry. Good luck, but don't count on it, hun. (=
Jan 2, 2012. 5:58 PMSamSamBunnyCat says:
You call 29 guys a small school?! I have 9 guys in the whole 8th grade!
Jan 3, 2012. 3:30 AMcailynmarie97 says:
Well i went frkm a school of over a thousand students (450 per grade) to 32 kids in each grade. It is really small for me!!!
Jan 8, 2012. 12:13 PMSamSamBunnyCat says:
I have 18 kids in my grade!
Jan 10, 2012. 1:41 PMcailynmarie97 says:
oooh that sucks!
Jan 4, 2012. 7:54 AMjiyeon94 says:
lol i'm turning 18 this year and I just had my first kiss.
at first I didn't really planned to do a passionate kiss but it just turned out like that and I regret nothing..
BTW that happened last January 02, 2011
before all the scenarios happened. . .there was this cuddling,holding hands,etc.so it kinda fLt comfformtable..
and oh yeah..
things just happened, umm like I haven't kissed somebody else before but it seemed like i've kissed alot of guys..that's what my guy said. kind of awkward but his fist question when we got out of that staircase was "are you sure this is your first kiss?? where did you learned that??"
>>HONESTLY THAT WAS MY FIRST
well you're still young at the age of 13,
yeah sure I've wanted to kiss someone before..
but enjoy your youth, and there's no rule stating that a person should have kissed someone at the age of 13..
and yeah.,just wanted to share^^
>if you're gonna get one, make sure you enjoy it^^
~>no regrets :D
May 14, 2012. 1:04 PMjalawashere says:
i love your story it is like a fairytale now you have the right not to sleep cause reality is way better than dreams
Jan 22, 2012. 5:26 PMviolet_skies43 says:
I love your story so much cos im in a very similar situation, im in high school and have never kissed ANYONE. im awkward HUGGING people, and my boyfriend is wicked shy and i just hope it ends well like your story did :]
Thank you for sharing!
Nov 2, 2011. 6:16 AMdani love says:
i am in the 5th grade and i met a girl and i liked her but how do i tell her that i don't want to kiss her i just want to ask to go on a date
(please help !)
May 14, 2012. 12:59 PMjalawashere says:
i think you should tell her u r not ready maybe in a few years or u like her too but it is not the time for that
good luck
i know it is too late to tell u but i just wanted to reply
Apr 15, 2012. 3:48 PMgshockwhite says:
ok im mike and im in 6th grade and i got a girl freind and we kissed . so if u want to KISS this girl u first must ask her out if your to scared to do that ask her with a note if she wants to be with you u should hug her every day and give her a kiss on the cheek . the best way to have a relationship with her is to notify her parents including your own or you could be sneecky with the relationship .
Apr 10, 2012. 2:51 PMlilly123 says:
im a girl and i know that all you have to do is tell her im in 5th grade and i had lots of boys tell me they like me so i went on a date with them
Mar 31, 2012. 8:19 AMkristina-na says:
simple tell her your not ready for a serious relationship and you just want to go on a date with her.who knows maybe she'll feel the same way
Mar 25, 2012. 7:13 PMRheaWright says:
Ok, your in fifth grade. You shouldnt be dating, let alone kissing! Just tell her!
Apr 10, 2012. 2:56 PMlilly123 says:
what grade are you in
Mar 19, 2012. 3:46 PMbrek says:
Hon you're in the fifth grade there's no rush...i'm in the tenth grade and just had my first kiss in september! believe it or not when its your time,it'll come. besides don't you think girls still have cooties??
1-40 of 1639next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
901
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
