How to Make a Bladder System for a Water Gun
PlayToys by
Introduction: How to Make a Bladder System for a Water Gun
today i will teach you how to get more power from a water gun by adding a bladder to it it only works on certain water guns but any one  who has a basic knowledge of how a  super soaker  works should have no problem doing this.
Step 1: Gather Materials
2 hose clamps
a Dremel with cutting wheel and sanding drum
party balloons
PVC cement
PVC pipe
shoe goop
Step 2: Take the Gun Apart
take your screwdriver and unscrew all of the screws and cut the pipe where the picture says to and make a plug like get up this will help the power output each pull and push
Step 3: Tank Modding Part One
take the water tanks off and set them aside for now
Step 4: Modding the Pressure Tank Part 2
take a piece of pipe and cut to about 1 and 1/2'' long and make it fit  snugly  and glue it in like  in the second photo (remember to dry fit first)
Step 5: Continuing With the Last Part
 make sure both pieces of pipe fit snugly and are glued in and let glue dry
Step 6: While the Glue Is Drying
while the glue is drying layer the party balloons 5 or 6 for each pipe(" you also can use flexible hose to make a bladder too this
works better in practice")
Step 7: After the Glue
after the glue is done drying put on the layered balloons like so and put on the first and second hose clamp
Step 8: Whip Out the Dremel and Finish Up
 make a large  enough hole in the old tank to go around the bladder like the picture below  ("and now would be a good time to dry test it .") it should work if everything is good
Step 9: Seal It Back Up
seal it up and go try it out and good luck and have fun
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
