Introduction: How to Make a Budget, Impact-proof Case
Picture of How to Make a Budget, Impact-proof Case
in this instructable, i made a cushioned carrying case for my airsoft rifle from items i found around the house...
Step 1: Gathering the Goods
Picture of Gathering the Goods
i used an empty case for a collapsible lighting unit and cushioning...tools i used are: a Leatherman, a Dremel tool (with various applicable attachments), an Exact-o knife, pair of safety glasses, a ruler, and a hot glue gun.
Step 2: Gutting Out the Case
Picture of Gutting Out the Case
this step isn't always necessary; if you have a nice case without molded innards, you can skip this step. i found it appropriate in order to maximaize the storage capacity.
i used a carbide tip with the dremel to score out the stamped anchors securing the facade of the molding. i then used a cutting cookie attachment in conjunction with an exacto knife on the soft parts to get some clean cuts.
brute force seemed necessary to rip out inside frame.
Step 3: Measure Twice, Cut Once...
Picture of Measure Twice, Cut Once...
after all is said and done with gutting the case out, i used a ruler to estimate how much cushioning i needed for each wall of the case. i used a sharp knife from my leatherman along with an exact-o knife to cut slivers of cushioning approximately 0.5" thick. after each cut, i eyeballed the piece to the wall of the case; it didn't have to be exact because sponge is form-fitting.
Step 4: It Puts the Lotion On...
Picture of It Puts the Lotion On...
once i was satisfied with the pieces i had cut, i laid in the spongy padding one by one after i applied the glue onto the sides. fortunately, my glue gun has 2 temperature settings...i used the lower of the two in order not to damage the padding. you can buy a cheap mini glue gun at the dollar store.
Step 5: Almost Done
Picture of Almost Done
after neatly adhering the pads into the box, you'll soon see some progress to the initial internal cushioning.
the key for this step is to keep a consistent width when cutting the pads.
Step 6: Time to Get Creative
Picture of Time to Get Creative
after the initial padding of the box was complete, i then used an airsoft rifle as an example to what this box can be used for.
as you can see, i also found some weather stripping and placed it around the edges to create somewhat of an airtight seal...it'll keep dust and debris out as well.
the approximate cost for this project for me was $0.00 because i found everything within my house; however, if you decided to do something like this you can find a box like and some padding just about anywhere someone might be throwing it away (i was about to). glue gun (dollar store) $1.00, hot glue sticks 50 ct (dollar store) $1.00, generic arts and crafts knife (exact-o) (dollar store) $1.00, weather stripping (walmart) $1.88. you don't really need a leatherman or a dremel...so your running total could be less than $5.00.
Step 7: Options
Picture of Options
i didn't do it yet, and i'm still thinking about it, but you can also modify the molding you cut out of the case to create an outer shell to fit miscellaneous objects like power cords, gaming console control pads, batteries, etc. inside of it...and maybe attach it with velcro...? just an end thought.
eventually, i will be making a bunch of different customized padded framework to fit my gaming consoles, laptop, pistols, and rifles
stephenniall (author)2009-04-13
Wow very nice i will make one for my laptop in the middle and two airsoft pistols next to it lol
psyoper22 (author)2008-03-05
if you look closely, the left side is done with a sillhouette of the upper receiver and my ACOG Trijicon scope cut out and embedded into more cushioning, but the left side wasn't complete when i took the pic.
mrmath (author)2008-03-05
You didn't mold the case to hold the stuff in that exact position. Does it fall round, or is it pretty secure? I'm picturing you closing that, and everythihng falls to the bottom (hinged) side.
psyoper22 (author)mrmath2008-03-05
yeah, i got so anxious with posting my first instructable, i didn't exactly finish; i got sidetracked, but once i get some time off from the job, i'm going to edit it. i hope you get the idea...
Ebz (author)2008-03-05
Very Creative... Good Job!
GorillazMiko (author)2008-03-05
Wow... incredibly nicely done job. The picture in step 5 looks really cool, like something store-bought. I might try this out (if I get the stuff somehow), and use it for other stuff, it's a great Instructable. +1 rating.
About This Instructable
3,974views
27favorites
License:
Bio: exmil hobbyist.
More by psyoper22:Recycled  MemoriesRestore Your Favorite Pair of Pants -- Very Easily!!Make a Free, Customized Desk-top Organizer during your lunch break!!
Add instructable to:
