How to Make Yourself a Bungee Kite!
1,444
Posted in OutsideKites
Introduction: How to Make Yourself a Bungee Kite!
About: I am a musician, i play the saxophone and bass, i am a boyscout, and really love to do creative, DIY things, however, i have VERY limited access to tools, so the things i post on this website, are for peopl...
A very fun, cheap, endless fun on a not-so-blustery day!
Step 1: The Things You Will Need....
You will need about 50 3" rubber bands(you could use more, for more elastic fun!)
A kite (I am not sure if using different kinds would matter, but my shark kite does perfect.
Something to anchor the rubber bands (i used my swing set).
An open treeless area.
Step 2: Step One!
first string all your rubber bands together
Each loop, i used the rubber band, to form a larks head knot, repetitively, for each band.
Step 3: Step Number 2!
now cut the string from the kite but not too far up
Make sure, you have a loop, to attach a rubber band too!
Step 4: Step 3, Tie It Up!
Now, tie, the end opposite of the one on the kite, to an anchor, it works best, if the anchor point is not directly on the ground, but it will work if that's your only option.
Step 5: Step 4, Pull!
Now, pull the kite back as far as you think you can without breaking the rubber, if the rubber does break, it can be VERY PAINFUL. i managed about 94ft. Good luck.
Step 6: Step 5! Hope It Does Not Snap, and Let Go!
WHEEEEE
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    2 Comments
    use rubber from bicycle or car inner tube its stronger
    my rubber bands kept snapping at about 100 feet still have huge welts
