How to Make a Cheap But Effective Airsoft Grenade
10,112
21
15
Posted
Introduction: How to Make a Cheap But Effective Airsoft Grenade
this is how to make a cheap but effective airsof grenade. Small than the waterballoon grenade, egg grenade, baking soda grenade, or anything you could go buy and just as effective
Step 1: Grocery List
alright part of these you can only get at new years or the fourth of july in america.
You will need some mighty crackers/ little dinamites about 1$ for 100
also some hot glue
and of course airsoft bb's
Step 2: Starting Out
put some hot glue in a strait row down the mighty cracker
start a row of six on the mighty cracker place them quickly but as straight as possible
 your going to do three of thes rows spaced evenly apart
Step 3: Now the to Fill in the Spaces
put some hot glue in one of the empty spaces and quickly put 7 bb's in it alternating with the rows of 6 to maximize bb capacity without jeprodizing the strength of the grenade
Step 4: Last Step
now on the end without the fuse we are going to add 5 bb's to the bottom
four corners and one in the middle (like the 5 on a die)
Step 5: All Finished
now we are done. we have a very effective airsoft grenade that is very small, whill also very cheap.
to light these i recomend you carry around a bic lighter or you can use two matches tapped to the fuse and a quick strike lighter
remeber that these may not be legal to use in your city limits since, they are infact firework
have fun
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    16 Comments
    Can i use super glue and stone instead of bbs
    This is a lot better then the pathetic vinegar and baking soda things. Finally something that explodes like a real grenade. You should make a pull pinn on the fuse by putting matches around the fuse and making a circle with the striker pad. Then put that over the matches and pull.
    y dont u just use normal glue or super glue?
    The bbs stick together too much and shoot in only one direction.
    i have tried both but they both let the bb's drop off while in your pocket or vest or watever, plus and this may sound a little weird, the firecrackers exsplosion helps the hotglue let go of the bb's so it works better that way too
    I've never seen grenades like this before but its a really neat idea!
    um hot glue on a fire cracker? sounds dagerous...
    don't worry it's not as dangerous as it sounds although it has good range and shoots the bb's pretty well, it won't seriosly injure. i have been using this method for years
    sure i'll try and get one done within the next week
