3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a fire
How to make a fire
There are several ways in which one can make a fire, in this Instructable I will demonstrate the basic steps.
WARNING: Fire can and will burn you if not used properly, don't be stupid and use caution when having a fire.
If you like this instructable please vote for it in the burning questions round 6 contest.
Step 1Fire methods.
Fire methods.
As I have already stated you can build a fire numerous ways. You can build a traditional teepee style fire, a log cabin style fire, or a lean too. And you can choose to light it with a match, flint and steel, steel wool and a 9v battery, fire bow drill, the classic magnifying glass/glasses, or another method.
50 comments
1-40 of 50next »
May 15, 2011. 8:30 PMplznothanks says:
Aug 3, 2010. 7:23 PMdood12314 says:
where did u get the flent
Apr 30, 2011. 12:01 PMducktape.mac says:
you get flint in walmart... actually just about any store with a camping section.
Dec 27, 2009. 2:45 PMlucek says:
flint and steel. enough said.
Feb 27, 2011. 4:21 AMmob1 says:
Box of matches. enough said.
BIC lighter. enough said.
Mar 5, 2011. 9:25 AMlucek says:
Bic lighter can't be brought everywhere and won't work if it get's wet. Matches are prone to wind problems and unless they are waterproof have same water problems. My flint I keep on my key chain in the form of a magnesium fire starter. My steel is and knife I have at the time It works on wet grass and in wind and after it's soaked it still works. IE.
Flint and steel. Enough said.
Aug 23, 2010. 11:32 AMDon,t try this at home says:
I tryed this and my string wont turn the stick i tryed useing shoe lacesnylon rope what am i doing wrong????
Aug 23, 2010. 11:34 AMDon,t try this at home says:
Ps i tryed the bow drill
Aug 20, 2009. 1:37 PMsomerandomguy says:
The fire ring should not be made of stones because they can crack from the heat. The fire ring is not always even necessary.
Feb 27, 2010. 8:05 PMjclarkt7 says:
I'm a boyscout and i have probably made close to 100 fire and all the ones that had rocks the rocks didn't crack
Apr 18, 2010. 12:18 PMPACW says:
 same here.
Dec 16, 2009. 4:36 AMCountryboy7239 says:
Actually, if you're in an emergency situation, it's smart to have some rocks with your fire. They absorb heat and keep it for a long time. When you go to bed you can take the rocks out (with a stick or something of course) and bury them beneath your bedding. The ground won't be as cold then.
non-emergency but still a good way to keep warm at night. Take the rock out and let it stay out for about 10 minutes, wrap it in a towel or piece of thick clothing and then set it in your sleeping bag at your feet.
The thicker the rock, the more heat it absorbs and the longer it will return the heat while you sleep.
Jun 20, 2009. 5:59 PMthe gizmoman says:
have you ever heard of a fire piston?
Mar 28, 2010. 2:35 AMstatic says:
I believe there's an instructable on making a fire piston.
Mar 25, 2009. 6:09 AMtotos says:
the most water-conserving way to put a fire out is to put some sand onto it or to pee on it (for guys only)
Mar 28, 2010. 12:28 AMstatic says:
Piss on the fire, call in the dogs and head it back on to bowlegs.
The nitty gritty dirt band
Hadn't though of those lyrics for a long time. Unless a lot a beer was held in uncomfortably, smothering the fire with dirt or sand finishes the job.
Apr 6, 2009. 9:44 AMtotos says:
why not?
Jan 10, 2010. 4:14 PMiLikeCoolStuf says:
LOL
Nov 28, 2009. 7:50 AMmowie says:
my friend put out a forrest fire with pee...the thing is he lit the forrest fire 5 mins before
Jul 25, 2009. 11:25 AMFrindledon3 says:
not unless you are whering a gas mask
Sep 11, 2009. 5:24 AMKaiouss says:
Urine is comprised of water and cellular waste; it is a sterile liquid and, therefore, a sterile gas. Apart from the horrible smell, you'd probably be just fine inhaling the fumes. Also, I assure you that dirt is not difficult to come by, so you should never be in a situation so hopeless as to require this method of putting out fires. Keep in mind also that it's a bit more difficult to control the aforementioned method of quenching flames and it should be especially avoided if you're in a dry deciduous forest with a lot of tender laying about. "Remember kids, only YOU can prevent forest fires."
Sep 17, 2009. 6:24 PMProject_Nightmare says:
"Remember kids, only YOU can prevent forest fires."??? Say that to the people that do controlled burns (forest fires are a natural thing).
Apr 12, 2009. 11:52 AMtotos says:
Yeah... you're right. Breathing your own pee in is definitely not fun. You just have to be careful when doing this.
Also, I meant putting sand AND peeing onto it (onto the sand.)
Jun 22, 2009. 6:58 AMMatt21497 says:
pee on a fire does Not smell good but is fairly fun
Sep 19, 2009. 2:36 AMthefunktopus says:
what would happen if you shat on a fire? thats my burning question!!
Jan 30, 2011. 12:51 PMjames4 says:
i thought of that just before reading your comment
Feb 27, 2010. 8:11 PMjclarkt7 says:
This is great, every method i use in boyscouts is in here, and they all work. But the bow and drill is difficult.Thanks
Dec 21, 2009. 8:00 PMBodygard1117 says:
your fire starting method can double as a hunting implement  :D
Oct 4, 2009. 7:05 PMCarpenoctem90hrs says:
Great instructable. I always thought that the size order was fuel, kindling, tinder (taught at a camp for a few years.)
Aug 16, 2009. 5:08 PMxando says:
do they make campfire thermometers
Aug 5, 2009. 11:57 AMsuperitchy says:
I wouldn't have put the suggestion for just dumping water. 1) it causes lots of smoke to go in your face, and 2) any excess water in the fire pit will make it difficult to light a fire later on.
Jul 29, 2009. 12:59 AMIdeal_Ideas91 says:
you got one big mess in the background i see :P
May 4, 2009. 4:36 PMojohnnyo69 says:
I carry a small bottle of Potassium Permanganate and a second small bottle of Glycerin. a drop of each together is combustible and poof a fire. Separately the chemicals are safe. Both of which can be found in any pharmacy. This was also shown briefly in segments of Survivor Man and Man vs. Wild.
Jun 28, 2009. 12:20 PMtotos says:
that is a very good thing, i used to carry some sort of homemade firestarters based on these two components. the only problem is that all the local pharmacies stopped selling theKMnO4.
Oct 17, 2008. 5:12 PMpyro man says:
magnesium shavings work well too
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Noname23
