Picture of how to make a halo magnum
with halo reach out and halloween around the corner you may want to be a spartan, but what is a spartan with out his guns. this instructable will show you how to make a prop gun and though i made a magnum im sure you could apply this same consept to make almost any prop gun
Step 1: What you'll need
Picture of what you'll need
foam board
hot glue gun
exacto knife or another cutting object
scizzors
pencil or pen
white glue
electrical tape
sand paper
paint
paint brush
 the computer you are using
and a printer
Step 2: The templet
Picture of the templet
you will want to go online and print of a side pic of the magnum, or other gun of choice.
you will the want o cut it out
i would print more than one of the pic
Step 3: Foam base
Picture of foam base
now you will want to go and trace out the templet on to your foam four times (if you do a gu like the magnum you dont want to trace the part where the the clip sticks out yet)
after that you can start to cut out the shapes. cut out the peices on the inside of the gun first
you have to be careful because the foam is thin and will bend and breack if you are not careful
Step 4: The clip
Picture of the clip
to make a clip take your to inner layer and trace out the shape and size of the clip
then cut it out and sand the sides alittle so it will slide easyer
be careful this will make the gun tin where the clip is taken from and will bend if not careful
Step 5: Glueing it all together
Picture of glueing it all together
its time to fire up the glue gun
prelay out the order that they go on
start to glue them on layer by layer
another option is to use white glue but it takes longer
dont forget to glue the clip
Step 6: Sanding
Picture of sanding
you will want to sand all of the edges down so they are all even
dont sand to much or it will ruin the gun
shadowop5554 months ago
cool
om nom nom. eating the foam.
Wow! i didn't know it was possible to turn foam into a tin?
vtheawesome4 years ago
can you post the pictrure you used i cant find it :(
ibayibay14 years ago
love the end warning: YOULL GET SHOT BY A REAL GUN lol
TFElite4 years ago
This looks nice! If I end up doing this, the only thing I'm probably going to do is add a bit more detail. Nice work, man!
