want to make a decent iPod/mp3 amp?
these speakers are powered via a PP3 9V battery
materials:
speakers
snap on clip for 9V batter
9V battery
audio source
tools:
soldering iron and solder
screw driver
wire cutters/teeth
wire stippers/teeth
Remove these ads by
Signing UpStep 1Disassemble speakers
disassemble the speaker with volume and power input, unscrew it from the back, there should be a transformer attached to the back, this is what takes the 230V (110V) down to 9V or the working voltage for your speakers.
on the transformer it should say the primary and secondary voltage, the secondary voltage should be lower, 9V hopefully, if it is not 9V you may still be in luck, if it is 3V use two AA batteries, if its 6V use 4, if its 12V use either 8 AA batteries or a car battery or gel cell battery, look online for one.
however, if you want, you can put a batter inside if you have room, or outside if you dont, and put the speaker cases back together.
here's a video that explains in inductors: http://www.youtube.com/watch?v=STDlCdZnIsw
With mine a freshly charged 9V battery lasted me about 5 hours, at about 1/4-1/2 volume. It depends on your speakers but in normal use they shouldn't draw much current.
won't you drain the 9v battery like, veeeery fast?
my transformer says: O/P:9V-1A
It's working perfectly though, sound quality is as good as with 230v from the wall^^
and i connected 9volt battery as power source, and i conect headphones to headphone jack.
it works, but audio quality is very poor. can you tell me what might be the reason?
my speakers are old so maybe its somthing wrong with my board???
hlp pls.
but i'm serious hehe.....great thinking keep it up....
