how to make a simple tool organiser
 by tgferreira184
when i was putting my bedroom in order, i found some 1 meter publicity measuring tapes.
after think a little, i figured out that I could build a tool organiser.
all you need is the measuring tape and electrical tape (is only to glue it on the wall)
later I will add something to let the screwdrivers spin, probably from a neck keyring.
Step 1: Assembling
to assemble you only have to make a hole in the point and using a ring, connect the keyring to the measuring tape and put the keyring in the screwdriver or make a hole by the 3cm (1 inch), put there a ring and use some electrical tape to secure the tape and the screwdriver.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
