3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to make a steel doming/dapping punch for jewellery making.
Step 7Polishing the dome
Polishing the dome
Once the dome was been sanded up to 1200 grit it should have a uniform face. To achieve a mirror finish it is necessary to polish the dome. This can be done either using a polishing motor or if you don't have access to a polishing motor with the use of a buffing stick.
To polish with a buffing stick load the leather with compound by rubbing the stick over the polishing compound. Then vigorously rub the stick back and forth over the surface of the dome. This is can be quite a labour intensive excercise and while a true mirrior finish is hard to achieve good results should still be possible.
NB: DANGER in the photos posted I don't have a guard on the motor. Not only is this bad practice it is extremely dangerous- polishing motor run at SEVERAL THOUSAND R.P.M. if what you are polishing goes flying there is a high probabilty you could be seriously hurt.
To polish using a polishing motor load the wheel by lightly touch the polishing compound to the spinning wheel. Hold the dome between 4 and 5 oc'lock on the wheel ( the position not the time) don't 'dig' the dome into the wheel but rather use a firm even pressure you'll get a feel for the correct pressure quickly. Move the dome so the face receives an even polishing (with softer metals it is possible to polish a groove into the surface- we don't won't this) Inspect your progress often.
Then rotate the dome 45' around its centre and start again- this is to polish out all the little scratches let by the 1200 grit paper as polishing perpendicular to a scratch is more effective at removing it. - repeat this rotation and polishing several times until the dome has been polish from all angles.
THINGS TO REMEMBER WHEN USING A POLISHING MOTOR:
NEVER OPERATE A POLISHING MOTOR OR GRINDER WITHOUT A GUARD ON IT
ALWAYS WEAR SAFETY GOOGLES
hold the item you are polishing firmly to prevent it from being pull from your hand
Take your time you'll get better results.
watch out that the piece doesn't get to hot, you can actually burn yourself.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:cr8ive1
