how to make a usb fan
 by zcarver
items need:
1. hobby motor
2. a cd
3.  hot glue gun
4. an elmers glue stick
5. a usb cable
6. scissors
7. wire strippers
8. tape
9. a hobby motor gear
10. a fan ( i cut one out of plastic)
Step 1: Step 1
cut off the head of the usb cable that doesn't plug into the computer. then strip the outermost shell from the cable revealing the inner wires. locate the red and black wires and discard the rest. strip the red and black wires.
munaib rumjaun says: Nov 13, 2011. 6:48 PM
MY USB HAS 3 WIRES
ITS AN OLD MOBILE EXCHANGE DATA USB WHICK I CUT
WHAT SHOULD I DO KNOW
spin498 in reply to munaib rumjaunApr 29, 2012. 6:06 AM
red is always power (or it's supposed to be)
black is always ground (see above)
tape off the other green? wire and the aluminum shielding.
zcarver (author) in reply to munaib rumjaunNov 14, 2011. 1:38 AM
I would strip all the wires and try different combination of each wire until you find the ones that are your power and discard the rest.
osh114 says: Dec 15, 2011. 10:24 AM
When your using a cd and you cut it, it will generally break. But if you melt the cd lines with a soldering the cd will not break. i will try to make a instructable on how to do it this way but thats when i have time. i will make a hyperlink later on.
osh114 says: Sep 9, 2011. 6:20 PM
I thought your fan was very creative and i made 1 that runs on a 9V battery, check it out. here is an image you can look at:
agis68 says: Aug 5, 2011. 1:41 AM
I enjoyed your presentation. Also liked the choice of the cd-fan ....simple, effective what else?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
