How to Make an Awesome Night Light (but It Doesn't Last Too Long)
Introduction: How to Make an Awesome Night Light (but It Doesn't Last Too Long)
this will show you how to make an awesome night light using a laser, wax, and a light bulb.
Step 1: Materials & Tools
the materials you will need are:
-a light bulb
-candle wax
-a laser pointer (can be green or red)
tools you will need:
-needle nosed pliers
-an exacto knife
-safety goggles (glass occasionally flies when shattered)
-an old sock
Step 2: Hollowing Out the Bulb
i got the the ideas and pictures on this step from CYNICALifornia
- Using your exacto knife or screw driver, pry up the metal disk on the bottom of the bulb.
- Use needle nosed pliers to pull it off.
Move outside! there will be shattered glass!
- take off the black glass that the metal disk was attached to. use pliers to chip/break it.
-Holding the bulb use the screwdriver to break the glass, and use the tweezers to pull it out.
- Use the screwdriver as a chisel once again and break the glass that holds the filament in place inside the bulb.
- Use your tweezers to break up pieces too big to fall out of the hole but simply squeezing them.
Step 3: Cleaning the Inside of the Bulb
-use a toothbrush and brush the inside of the bulb while still dry
-fill the bulb with water, and continue scrubbing until the bulb is completely clear
Step 4: Filling It With Wax
-dry the inside of the bulb with a hot air dryer
-melt enough wax to fill the lightbulb, and use a funnel to fill the light bulb
-let it cool
Step 5: Breaking the Glass
-put on protective gloves... glass can hurt! also, lay down newspaper (glass will get everywhere otherwise)
-take a small hammer, and lightly tap on the glass
-once it cracks, remove the pieces, making sure that there aren't any left in the wax
Step 6: Hollowing Out the Wax
now, use a small tool (screwdrivers work well) to hollow out the inside of the wax bulb. hake it wide enough so a laser can fit in it.
Step 7: Turn It on in the Dark
fit the laser into the hollow, and turn it on! the result should be a strange pixelated light, that works especially well in the dark.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    As an alternative, you could fill the lightbulb halfway with wax, drop in an LED that's attached to two very long wires that run out of the bulb, and then fill it the rest of the way with wax. Then you can attach the LED to a longer lasting power source, like a D-cell or two AA batteries. I like the thought though. The wax would probably diffuse some of the more harmful rays of light that the laser produces.
    you can use a resin also ( cloudy or not) but it would be hard to get the glass from the bulb off
    that was my origonal idea, but i didn't have any led's, so i used the laser.
    Why not use a few super bright colored LEDs? Would last much longer than a laserpointer
    that would probably work a lot better...this was just a first effort.
    woudn't it be a little stronger with the glass still intact?
    your expetriment rocks serious tankhs
    easier way to clean out your light bulb: pour about 2 or 3 tablespoons of salt/sugar into the bulb then swirl it around. Salt works best because the crystals are rougher. takes about 3 to 5 minutes of swirling. Also reduces the risk of breaking your bulb with the toothbrush
