3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to make an awesome night light (but it doesn't last too long)
how to make an awesome night light (but it doesn\
this will show you how to make an awesome night light using a laser, wax, and a light bulb.
Step 1Materials & tools
materials & tools
the materials you will need are:
-a light bulb
-candle wax
-a laser pointer (can be green or red)
tools you will need:
-needle nosed pliers
-tweezers
-an exacto knife
-safety goggles (glass occasionally flies when shattered)
-funnel
-hammer
-gloves
-an old sock
29 comments
Jun 16, 2008. 7:30 PMWTHAI says:
As an alternative, you could fill the lightbulb halfway with wax, drop in an LED that's attached to two very long wires that run out of the bulb, and then fill it the rest of the way with wax. Then you can attach the LED to a longer lasting power source, like a D-cell or two AA batteries. I like the thought though. The wax would probably diffuse some of the more harmful rays of light that the laser produces.
Apr 3, 2011. 4:20 AMCyclonicNinja says:
you can use a resin also ( cloudy or not) but it would be hard to get the glass from the bulb off
Jun 17, 2008. 11:28 AMpaprika killer says:
I'm so gonna make that.
Jun 16, 2008. 11:24 PMbenthekahn says:
Hey, you should come over here. I got some glowing LED circuits. We should try this with one.
Apr 1, 2010. 12:17 PMjgeekw says:
Why not use a few super bright colored LEDs? Would last much longer than a laserpointer
Nov 1, 2008. 8:11 PMberky93 says:
woudn't it be a little stronger with the glass still intact?
Jul 21, 2008. 11:05 AMhamxa says:
your expetriment rocks serious tankhs
Jul 20, 2008. 9:27 AMjgeekw says:
easier way to clean out your light bulb: pour about 2 or 3 tablespoons of salt/sugar into the bulb then swirl it around. Salt works best because the crystals are rougher. takes about 3 to 5 minutes of swirling. Also reduces the risk of breaking your bulb with the toothbrush
Jun 21, 2008. 11:43 AMaustin says:
the laser gives it that weird particle like look like a whole bunchy of little specks moving around
Jun 16, 2008. 1:36 AMexplosivemaker says:
ha ha ha.......thats great.......I would probably keep the glass on it and put at least one super bright LED inside instead of a laser..... ......you have given me cool idea though........lightbulb candles.....just stick a wick inside, add the wax, break off the glass, and presto.......a bulb candle........
Jun 17, 2008. 2:19 PMexplosivemaker says:
.....kinda the idea......i was thinking the other way around......
Jun 15, 2008. 8:02 PMjoejoerowley says:
Cool! Do you mind if I post another instructable based off of yours? Thanks
Jun 17, 2008. 1:02 PMjoejoerowley says:
It will be changed around a fair amount and I will credit you of course. :)
Jun 17, 2008. 9:37 AMslimguy379 says:
well if your laser burns out etc. you can turn it upside down and put a wick in it and turn it into a candle it will be a variation of CYNICALifornia's oil bulb.
Jun 15, 2008. 4:53 PMstonehenge360 says:
I noticed that pixelated effect inside the dot of a laser. I have never found an answer to what I am seeing, but my only guess is that it is the interference pattern from the light waves as they exit. anyone else got a better answer? if you want to see what we're talking about, point your laser at a normal lightbulb in a dark room - you will see strange light and dark specks....
Jun 17, 2008. 3:36 AMSinglefin says:
That's pretty much spot on: the speckles you can see are an interference pattern from the laser reflecting off a surface. You only get it with laser light because it's coherent, unlike non-laser light. The pattern you can see actually exists in space, rather than on the wall or whatever. If you're short-sighted, and shine a laser onto a far wall and whip your glasses off, the speckles are still perfectly sharp.
Jun 15, 2008. 7:02 PMzjharva says:
i know what you mean! although the only lasers i've had were cheap $1 ones.
Jun 17, 2008. 1:55 AMschumill says:
very nice,sometimes i try to make out blue light,anyone made it?the guide and the material?
Jun 16, 2008. 9:04 PMbenthekahn says:
Cool. What about a blue laser?
Jun 15, 2008. 9:53 PMYuffie says:
pixelated light?
must be photoshopped.
=d
Jun 16, 2008. 7:20 PMorangesrhyme says:
Naw, lasers just look sparkly like that. Just shine one at a matte metallic surface, and you'll see what I mean.
Jun 16, 2008. 8:09 AMzecapataintuna says:
you can clean out the stuff inside the bulb by swirling salt inside of it. It takes off almost all of it, and then you don't have to even wet it.
Jun 16, 2008. 12:41 AMPatrik says:
Nit going to last very long as an actual night light though. Most laser pointers aren't means for continuous use. Encasing the laser in sold wax isn't exactly going to alleviate any overheating. And even if the laser survives being on for a substantial amount of time, the battery will run out well before the end of the night. Looks nice though! :-)
Jun 15, 2008. 7:44 PMMadMechanicMike says:
nice, i saw this on Hack-a-day and i was like, this should be an instructable
Jun 15, 2008. 4:38 PMdcmania21 says:
good job i like it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:the4est
