3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to make an ear v.3
Ok then, ... after v.1 and v.2 on the same subject, ... EARS, if you're to lazy, or you just want perfection or need a quick solution to have a bunch of them ears, the answer is to work with moulds .
In this case I wanted the most exact similarity with the real actors ears.
For this project you'll be needing:
- a person
- 1.5 litre plastic bottle
- water (distilled if possible)
- 1 cotton ball
- alginate
- plaster
- silicone
- resin
- vaselin (or any other lube)
- fibre glass (optional)
Step 1Alginate moulding
alginate moulding
For the actors ears mould I use alginate bought at medical supplies stores to achieve detail but mainly because it's quicker and cheaper than the artists one. The medical brand is used by dentists to make teeth moulds and comes in a variety of flavours and may or not have a colour indication scheme.
Let me explain it, ... it has one colour when in powder (generally whitish), a stronger and darker colour when you mix water and then it turns back again whitish wend dried.
So, let's start.
Grab a plastic bottle with its bottom cutted off, large enough the put around the ear and still having almost 1 inch distance to the ear all around.
Ask the person to clean his ear and apply lube everywhere on and in his ear. For security reasons also apply on nearest hair.
Put a little cotton ball with lube inside the ear just to prevent the alginate flowing deep inside.
Read the mixing instructions of your alginate. Generally it's a half water / half alginate mixture. Using cool water will make the alginate to dry slower if the 3 minutes range is to fast for you. An artists alginate takes more than 10 minutes to dry.
6 comments
Sep 12, 2011. 8:37 AMflyingpuppy says:
What did you use the ears for?
Sep 12, 2011. 6:49 PMflyingpuppy says:
Muito legal! Vou ter que seguir o teu trabalho.
Sep 10, 2011. 10:43 AMrimar2000 says:
I was about 10 years, and I read in a magazine how to make a paper or cardboard mask, glueing paper strips. Very easy, but I had to have a plaster cast. Suddenly I had a flash of inspiration: why not use my face to make the mold? So I set to work: prepared enough liquid plaster in a bowl, filled my lungs ...And put my face in the cast! My mother watched from afar, and thought I was crazy (she was not mistaken!). I held my breath all I could ... and pulled my face dripping plaster. The incident was widely reported, both inside and outside the family.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:enVide neFelibata(Drawing Board)
art director at "Teatro e Marionetas de Mandragora" beer-coaster collector urban sketcher programmer wannabe open source geek www.envide.marionetasmandragora.com www.marionetasmandragora.com
