3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to make an earth box!
Step 3Step 3
step 3
insert pvc pipe! best if it's angled. now time to fill the tub with dirt. first top off the pots that are visible with dirt. these will wic water from the reservoir up into the rest of the tub. continue to fill with dirt, watering it down as you go along so it settles, and fill it TO THE TOP. this is the only time you will water the dirt directly. the rest of the time you will use the pvc pipe to fill the reservoir with water. scoop a shallow trough lengthwise out of the dirt and fill with dry, granular, fertilizer. take your plastic (garbage bag, or landscaping plastic) and cut a rectangle about three inches longer and wider than the top of the tub. lay it over the top of the tub and use the rim of the lid to clip down and hold it in place. you will not remove the plastic again. you cut holes in the plastic to plant your seeds/plants and voila! you done it!
8 comments
Mar 5, 2009. 1:09 PMsalvia71 says:
good idea with using the pots...the "floor" needs holes drilled in for aeration between the mix and water....and also you dont use dirt in these, you use a soilless medium for it work to properly..i have built one of these using 4" pvc pipes and used the egg crate light panel covers for the aeration screen.....good idea with using the pots..i may try using the lid as an aeration screen on some of the ones i'm making...
Aug 16, 2010. 11:40 PMsybertek says:
Actually he/she is correct in making this and using soil. It is called an earth box not a hydroponics resovier. I have a huge hydroponics setup in my home as well as a large garden. My hydroponics are all water and nutrient feeders but wanted to do a earth box and this person has done it correctly except like you said the bottom could use some air holes but for you to say yoiu don't use dirt in these is wrong. You may want to do your homework and read about earth box before you say he made it wrong which he did not. Good job on it. I was looking for a much cheaper way to make it then the professional earth box at their website and this will work perfect.
May 23, 2011. 10:22 PMbucklipe says:
By the way I suggest you look at the site, it clearly states "bag of organic potting mix". This excludes any soil that has nasties in it. The potting mix is just the matrix that the roots grow and holds the fertilizer stripe and provides water through capillary action. It is potting mix that is sold at the Earth Box Research Station in Ellenton, Florida. I've taken several of their free seminars on Earth Box home gardening. Each time they strongly tell you , "Do not use soil, dirt or anything other than potting mix."
Apr 16, 2009. 9:44 AMscrewlewse says:
I would love to see how you did that salvia71. I have made two earth boxes using a similar style to this instructable. The only difference is that I made holes in the floor for aeration. Otherwise I used potting mix etc.. and they work great. I dont compeletely understand your comment, if you could elaborate. :D
May 7, 2009. 12:09 PMbucklipe says:
I think the "egg crate light panel " that Salvia71 is using is the suspended ceiling plastic inserts that you put into the grids.
May 7, 2009. 12:04 PMbucklipe says:
I would drill holes in the lid/floor and cover it with weed block fabric. Cut the fabric to allow the potting mix to fill the two pots. There are several "secrets" to the EB. One is the water supply below with an air gap between the water and the soil. This allows the water to oxygenate. The next is the two soil columns that wick water up into the potting mix. Potting mix, not soil or dirt or any nutrient containing plant growing matrix. The fertilizer is applied in a stripe or stripes between the plants which allows the plants to take as much as they need. Make the stripe by running a finger through the mix to open a slot, fill with fertilizer and cover with the potting mix(Next growing season remove the old stripe and refill and recover.) The next item is the potting mix mounded up above the rim of the box and covering with the plastic sheeting. This sheds water and prevents the fertilizer from being washed down into the water and concentrating the fertilizer salts. Each of these points are vital to the EB usage...
May 23, 2011. 2:22 PMbriantorrey says:
Sounds good Bucklipe, thanks. And thanks as well to mnd for the original post. I built mine with a mound as suggested to avoid over-quick use of fertilizer, but did not use weed blocker on the bottom, just stuffed some of the gaps with coffee bean bag burlap. Otherwise I did everything form mnd's original post. That said I wonder about using compost tea in the box: do I need to use a fertilizer row? I'm using potting and planting mix from Costco, do I still need the fertilizer row?
Thanks for any help. BT
I know this is almost two years since the original post.
May 23, 2011. 10:06 PMbucklipe says:
You did good with the burlap. It's just anything to keep the planting mix out of the water and let roots grow down into the water if they want to. The fertilizer row is essential. It keeps the fertilizer salts from accumulating in the water. The plants will grow "feeder" roots over to the stripe and use what they need. Most of the potting mixes that we buy have a small amount of fertilizer in them. Usually it is insignificant compared to the Force. Oops, sorry my quoter ran amuck. Even with the small amount in the mix put the stripe between the plants and away from the holes the plants grow through. This way any rain won't wash it into the water holding area. As for the compost tea, I would recommend you use it on other planting methods. This procedure has been worked out through trial and error on campus at the University of Gainesville and has been in use in commercial farming as well as home use for 15-20 years. The inventor lives about 15 miles from me. I visit his Earth Box Research Station 2-3 times a year to buy stuff and just to marvel...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mnd
