Introduction: How to Make an Instructable of a Sun Set and Grass
In my first Instructables I am going to show you how to draw a sun setting and then I will also show you how to draw and make grass.
I decided to do a instructable on how to draw a sun setting because I made an animation on aliens and i wanted to do my instuctables related to my animation , I also wanted to do my instructables on something I drew in my animation
Step 1:
In the first step you will gather all your supplies you will need a white board you will also need a camera to take a bunch of photos or video . You will also have to gather the markers you will need to use you will gather green for the grass and purple and black for the sun you will need to grab plastic grass from the dollar store for the grass
Step 2:
- In the second step you will finally start to draw the sun with a circle.
- After you draw the circle you will start to draw lines on it to make the sun rays.
- Then when you are done drawing the sun rays all over the sun you will start to draw the eyes and make glasses
Step 3:
In step 3 I will show you how to draw the sun setting you will start with lowering it each time you draw the sun when you get lower towards the ground you will draw a half circle and start with drawling the rays you will start with a long one then you will do a short ray and repeat the rays in till the sun is covered then start do draw the eyes and when your done both eyes then start to draw the sun glasses once your done all that you have your half sun
Step 4:
In my 4 and finale step of my instructable I will show you how I made the grass for my animation you grab 2 pieces of plastic grass from the dollar store you will also need to grab a piece of foam and make it look like grass and put them against the white broad you will need 2 pieces of the grass and have a gap in between them and in the gap you will start to draw the grass with the markers if your 2 pieces of the grass are not the same size the you will draw grass over the one that is not the same size as the other one to make it even so that the grass is the same length .
