3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to make charcoal pencils
Don't want to pay for expensive charcoal pencils?
Learn how to make your own with a cheap, easy way.
These pencils in my opinion are as good as the ones you buy.
Step 1Build a fire
Build a fire
Now you need to build a fire.
1. Take some tinder and light it,
2. Put small pieces of wood on the lit tinder.
3.Gradually add bigger pieces of wood.
4.Wait for the fire to build up.
Your fire is made =).
63 comments
1-40 of 63next »
Apr 15, 2010. 5:43 AMjilllindseyw says:
 do you have any suggestion on how to get darker or lighter charcoal.
Nov 21, 2010. 9:58 AMhruodger says:
As far as I know, the "color" of the charcoal depends on two factors: the first, is the type of wood (cedar, mahogany, oak, pine, etc), because of the inherent grade of natural compression the wood has, and the inherent chemical compounds content in the wood (alcohol, proteins, metals, etc), hence the hardness of the wood (just like graphite leads); the second factor is the "cooking time", proportional to the amount of material that has been subject to pyrolysis process.
I suppose you should do some previous tests to determine which one is darker or lighter.
Hope my answer helps you.
Apr 16, 2010. 2:08 PMmousewrites says:
This type of charcoalis what is referred to as "vine" charcoal. Darker charcoalis generally Compressed charcoal. Here's a Wikipedia article on both.
Basically, to get darker charcoal, you take the vine, grind it up, and compress it with a binder. Not sure what binder you would use for home use, but i'm interested in trying it.
Great instructable, btw!
Feb 20, 2011. 9:00 PMnightninja87 says:
could you use a little clay to bind it?
Apr 15, 2010. 2:09 PMjilllindseyw says:
 lol I understand how to get a different tone from pressure but im talking about the actual color of the charcoal I'll try different types of wood as well. Thanks for the thorough answer its much appreciated keep up with the awesome Instructables good sir.
Apr 15, 2010. 4:36 PMGeekyGirl1103 says:
GAAAAASP.
I LOVE to draw with charcoal, but I'm always too broke to buy some. Thank you SO much.
Jul 27, 2008. 11:36 AMThe Jamalam says:
take knex out of the keywords, it is irrelavent
Jul 27, 2008. 1:27 PMThe Jamalam says:
well, put it this way, why is it under knex in the first place?and also, how is it relevant in any way??
Aug 21, 2008. 10:11 AMlawizeg says:
You're obviously doing it to get more attention. Instead of messing up the search engine, you should make an Instructable that will get attention for what it's worth.
also, this is very bad for the environment. the smoke, the fire, ugh.
Apr 15, 2010. 3:56 AMnutsandbolts_64 says:
lol, use pyrolisis
Apr 15, 2010. 8:23 AMnutsandbolts_64 says:
Besides, the fuel is renewable!
Jul 28, 2008. 6:45 AMThe Jamalam says:
because they are the laws of this site. And you still haven't answered my questions
Jul 28, 2008. 12:31 AMThe Jamalam says:
that is the point of keywords! They are relavent to the instructable so that when you search for any of them, it comes up!
Jul 28, 2008. 5:29 AMThe Jamalam says:
i know, but this would clutter up the k'nex search menu, and we would not want that. Someone might think this is knex, only to find it's not, and have to go back, wasting maybe valuable time. Could you do that to someone?
Aug 21, 2008. 10:13 AMlawizeg says:
You one of those people that doesn't care, and that noone likes because of that. that guy that takes the nacho with the most cheese because he "felt like it".
Aug 31, 2008. 12:37 PMThe Jamalam says:
i care about knex
Jul 28, 2008. 6:34 AMThe Jamalam says:
but, you're breaking site rules. I could always tell ewilhelm to ban you...
Jul 28, 2008. 7:23 AMThe Jamalam says:
you could have just removed it and saved me he bother
Jul 28, 2008. 8:36 AMThe Jamalam says:
or maybe you could have
Jul 28, 2008. 11:38 AMThe Jamalam says:
okay, fine with me
Apr 14, 2010. 6:15 PMzascecs says:
Hey, this is actually a pretty good idea; I don't see why people are rating this instructable so badly...
Jul 11, 2009. 3:11 PMLiaVivas says:
Hey! great to know about this, thanks! It reminded me of an article I read a litlle while ago about this pencils made out of old newspapers. So I was thinking that if you are into recycling that can be an alternative to the cloth under the resin. Although in those pencils they didn´t use resin just a adhesive solution resistant to water (of the sweat from the hands I suppousse). The thing would be to know if this homemade charcoals are strong enough to resist the process, they seem to be fragile. I´ll see if I can try this but if you do, let me know!
Nov 24, 2008. 3:31 AMgoogbar says:
i was told that the best pencils come from grape vines... i guess if you wrap the charcoal with a pice of cloth and epoxy / polyester resin (fiberglass stuff) you can make a fairly hard and decent pencil, sharpenable too, with those big mouthed sharpeners.
Nov 24, 2008. 5:27 PMgoogbar says:
I'm not very sure of this too, but my guess is that any decent hardwood will make good pencils, like the stuff you guys have in America, like oak, osage, redwood, mulberry, apple, cherry etc etc etc... :D Hey, try the epoxy/resin thing and tell us if that works!
Nov 25, 2008. 4:09 PMgoogbar says:
Keep it as homework, once the snow melts ;-) However, the epoxy resin you can get even at wal mart (look at tool/paint department) you'll need araldite stuff, like those mix and apply. The polyester resin is sold at paint stores, specially car body work ones and also at marinas, cause many boats are actually made and repaired with it. Looks like you're a handy young man, so I strongly suggest you learn how to work these materials, even with no relation to your pencils, cause you can make lots of things out of epoxy and resin, ok? Take care however, and I don't know about the resin, where you live, but they won't sell it for minors here, cause sadly many smell the stuff as a drug... :-(
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:GlueyMcGee
