3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to make my pneumatic gun
In this instructable i will show you how to make a gun that i have made from my own plans and have been modifying for a long time. This one is a small caliber (10 mm) high preasure (3-4 bar) type.
Bear in mind this is my first instructable but feel free to pick at the design and constructively comment;-)
i take no responsibility for any cats/humans you kill with this!
(i will upload a video of it being fired soon!)
most of the parts specified can be found at screwfix direct, but you may want to buy the preasure guage off ebay or somewhare like that because i payed about £25 for mine!
please rate & comment!
PARTS:
Step 1Firstly, how to use compression fit plumbing...
firstly, how to use compression fit plumbing...
  • C:\Documents and Settings\joe\My Documents\DSC01179.JPG
  • C:\Documents and Settings\joe\My Documents\DSC01182.JPG
  • C:\Documents and Settings\joe\My Documents\DSC01183.JPG
  • C:\Documents and Settings\joe\My Documents\DSC01185.JPG
see the pictures
53 comments
1-40 of 53next »
Apr 6, 2012. 7:54 PMMarkie BOYY 15 says:
this is a vary good man but i think i may have a better one that will actually shoot arrows and be able to bring the arrow back to you with a fishing reel set u
Oct 19, 2007. 6:30 PMreceiver545 says:
i wished i could make it !! but in america copper is expensive! i will ry to make one out of PVC instread! yu should try it itll be lighter! are you from the UK cause those are british bakery potatoes!?'
Oct 20, 2007. 5:06 AMreceiver545 says:
yea but we have PVC !! its cheap here! really cheap!
Jan 25, 2009. 2:36 PMNetReaper says:
but it can explode into shards if you dont check the psi rating, (if it has one)
Mar 13, 2009. 12:29 AMXkidXhavocX says:
copper will explode easier because of the fact that it is supposed to be used for water piping.... not pneumatics....id be more worried about the copper
Jul 11, 2010. 3:11 AMlemminggenocide says:
the weakest type of copper (type m) is rated to 250 psi. that's 250 pounds of pressure per square cm, regardless of whether it's water or air. Since he's using a regular bike pump, it won't go over 100 ps1. the most serious injury you could get from a basic ball valve pneumatic like this would be from dropping it on your foot.
Jul 5, 2011. 3:58 AMmake.it.then.break.it says:
u mean square inch?? pounds per square inch!
Oct 21, 2009. 4:59 PMMINIMOOSE101 says:
niether is pvc id use threaded steel but i would be HEAVY but you probably wont get high enough pressure to make it explode even eith co2
Jul 13, 2010. 3:30 PMguitarmonk15 says:
I wonder, what if you had a gravity fed magazine (after the valve). It would be easier to use bbs if you added one. Would it work?
Feb 15, 2009. 5:34 AMraring1996 says:
how much does all parts costs??
Jan 2, 2009. 1:28 PMgearofwar123 says:
1. What air source should i use? 2. can i use a paintball co2 tank? 3. How can i fire 10mm, 7mm nails or whatever?
Jan 2, 2009. 1:29 PMgearofwar123 says:
And how far do the wall plugs go? like 300 feet?
Feb 12, 2008. 1:24 AMblugyblug says:
Where can u get Pressure Guages and Ball Valves?
Nov 24, 2008. 8:07 AMLED master22 says:
dude like home depot
Nov 25, 2008. 12:26 AMblugyblug says:
Yeah i know... I found out about half an hour after I posted that... And i still know 10 months late r 0.0
Jun 3, 2008. 10:07 PMbrandon borick says:
nice bd (bearded dragon) how old is it iv posted to bd care sheets on this site
May 31, 2008. 1:25 PMDerin says:
i know a funny dialog about pushfits plumber-we just cracked the pushfit boss-dont worry i have an extra plumber-then give it boss-are you joking plumber-(awkward silence) me all the time-heheheheheheheheheheheheehehehehehehahahahahahaha
Mar 8, 2008. 12:20 AMblugyblug says:
Wait nvm... Great gun though. But the dragon owns ur gun.
Dec 31, 2007. 4:03 PMmichoi says:
i suggest u solder the olive on to the pipe
Jan 19, 2008. 3:57 PMlasermaster3531 says:
olive has to slide
Dec 31, 2007. 4:00 PMmichoi says:
that gun is awesome since you can take it apart for cleaning
Dec 31, 2007. 3:58 PMmichoi says:
500 psi
Nov 15, 2007. 7:34 AMcasvandegoor says:
I thought you can use a much higher presure when using copper
Nov 16, 2007. 10:22 AMcasvandegoor says:
ow, ok, nise and neath gun by the way!
Aug 26, 2007. 5:32 PMgotja says:
klol im gonna amke one well another one but kinda differnt from urs and maby try to find 6 mm so i can fire bbs
Aug 29, 2007. 4:08 PMgotja says:
hmm maby i could use a bigger pvc pipe and either make a grenade launcher(basicaly a baloon or a easter egg with a small charge with bbs inside) or make a giant shotgun
Jul 25, 2007. 1:15 PMzach911 says:
how much does it cost in total to make it?
Aug 14, 2007. 12:07 AMoinkoinkzoopals says:
umm do you no how many us dollars ten pounds is equall to
Jul 12, 2007. 4:45 PMtomonto says:
hmmmmm...bearded dragon+bycicle pump+gun thing=world domination ahhhh... i see your plan now
Jul 19, 2007. 10:16 AMlawizeg says:
lol
Jul 13, 2007. 12:24 AMjtobako says:
...but will the harness that holds the pneumatic gun on the bearded dragon hold the barrel over it's aiming eye or-for balance-the other side? And, will the limited field of binocular vision negatively impact the, um, impact area?...
Jul 14, 2007. 12:58 AMjtobako says:
Via Nevada testing grounds or Bikini I presume?
Jul 14, 2007. 7:03 AMlemonie says:
I like the all-metal construction, make a bigger one? L
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rocketbat
