It's an excellent way to get custom nail polish colors you couldn't get otherwise. And I love the way this nail polish goes on and the way it dries - it's much more matte and shimmery than regular nail polish.
Plus, making your own nail polish is very cheap and fast - so why not give it a try?
P.S. Know there are lots of tutorials on how to make your own nail polish floating around online, but I really wanted to give it a try. :D Even sunshiine has one - make sure to check her instructable out!
Step 1: What you'll need:
- clear nail polish
- eyeshadow (I bet blush would work too!)
- craft glitter
- a couple sheets of paper
- a toothpick
The polish is pretty runny, but that's the only downside. :)
Step 2: Empty out some of the polish
Pour a tiny bit of polish out of the bottles into/onto something you were throwing away anyway. I used a ziploc bag. You'll need extra room in the bottle for the eyeshadow or glitter you're adding.
In the picture, the polish on the left has had a little poured out, and the polish on the right is a full bottle.
Step 3: Make a paper funnel
You'll need a new funnel for every color of eyeshadow or blush you use, otherwise cross contamination is going to happen!
I folded a piece of printer paper twice so I ended up with fold lines to cut it into four smaller pieces and then used those to make my funnels.
Not sure how to make a funnel? Check out my instructable. :)
Step 4: Prep the eyeshadow
Step 5: Funnel it into the bottle and shake!
Use the piece of paper you've chopped the eyeshadow up on to transfer the eyeshadow - just fold it in half and tip it into the funnel.
Tap the funnel to get the eyeshadow to fall down into the bottle. If the eyeshadow gets grumpy and starts to clump at the bottom of the funnel, use a toothpick to help push it through. This happened almost every time.
Try to be quick while doing this, otherwise the nail polish brush can dry out and you'll have to get the nail polish remover after it to clean it up.
Screw the top back on and shake like a madperson. I did lots of shaking and rolling it between my hands - it took a minute or so to get everything nice and smooth. You don't want to see any clumps or dark spots in the polish!
This polish will settle after it's been sitting around for a few hours, but it is easily remedied by a bit more shaking. :D
If you're unsure about how much eyeshadow to use, see the next step!
Step 6: How much eyeshadow should I use?
I'm not a fan of sheer polishes, so I went with the full 4 oz tray of eyeshadow.
Both photos are shown using only one coat. :)
Step 7: Glitter polish!
I used the same method as the eyeshadow - tipped some glitter into the funnel and then lots of shaking. I'd say I used about 1/2 teaspoon of glitter per bottle. You just want it to look nice and full when shaken.
Keep in mind that the glitter will settle to the bottom when not in use - just shake well before every use and shake occasionally while applying too and you'll be good to go!
Step 8: Final photos + comments
The glitter polish turned out great as well - just make sure to do a clear top coat over it because craft glitter can be a little chunky. You don't want the glitter snagging on your clothes/hair/pets/whatever. :D
Now we'll have to see how long it lasts! I ended up doing a base coat of the purple polish I made, covering that with the gold glitter polish, and topping that with a clear top coat. I'll report back! It's held up well so far and I've had a hot shower and washed a load of dishes since yesterday.
POLISH UPDATE: It ended up lasting four days, which is not bad for cheapy nail polish. I think I could have worn it longer - I only had one tiny chip on my right hand! Came off pretty easy too, but the glitter is always tricky. :)
COMMENT UPDATE: A few of you have suggested putting either a bb or a glass bead into the bottle to help the polish get mixed. I'm going to do this myself and I think anyone who tries this should do it too. I hadn't thought of it! :D
Visit Our Store »
Go Pro Today »
The pictures below give you an idea of the various kinds of pill crushers available on the market today. As you can see there is one for everyone no matter what ailment you may have. They do make automatic pill crushers if you have problems with your hands.
The first one is available at Walgreens for around $7. This is the one I use. It all comes as one piece that breaks down into 3 separate sections: the pill cutter on top, the crusher in the middle, and the drinking cup on the bottom. I found that to just use the crusher, the pill cutter is a real pain and is in the way and more difficult to use. I took it off permanently, but when I need to use it, I do not need to put it back onto the other two sections. It is still very easy to use without being attached to the parts.
http://www.lescreateliers.com/Les_Createliers/Idees_Ideas/Entries/2012/9/6_Vernis_a_onglesNail_polish.html
Cheers,
Marie-Eve
One little thing, my eyeshadows were loose powder to start with, so didn't need crushing, which I reckon made it much easier: plus I had a tiny funnel that came with a cheap refillable perfume atomiser, these might be worth looking out for.
Thanks so much for the inspiration :)
I tried it , and the bbs rusted.
Great ible. I have a niece who will be trying this.
Thanks.
something like this
http://www.ebay.com/itm/1-Oz-Metal-Flake-U-Pick-Color-Automotive-Grade-Free-Ship-in-USA-custom-paint-/251116874441?pt=Motors_Automotive_Tools&hash=item3a77bb6ac9&vxp=mtr#ht_1478wt_932
My nail polish is always destroyd after washing dishes :(
When I use topcoat, it chips even faster...
Sally Hansen Insta-Dri doesn't smooth things out quite as nicely as the other two, but it's fantastic. The other two are wonderful at smoothing out bumpy nail art or rough glitters. All of them dry your nail polish to the touch within around a minute, and I wouldn't be able to actually wear nail polish without them.
where do you buy your topcoat?
BTW I love your easy ombre manicure :)
Are there any cosmetics stores near you? It might be worth looking to see what topcoats are available there. If not, just check the nail polish sections of your shops. I'm sure you'll be able to find something worth trying!
i'm hopeless at painting my nails
I'm not much for nail polish - I'm in IT, and brutal on my nails - but my daughter will love trying this!
