loading
Step 4: prep the eyeshadow
Use a butter knife or whatever you like to scrape the eyeshadow from the compact and onto a piece of paper. Then chop the eyeshadow up - you don't want any big clumps, because those will be trickier to mix into the polish.
I actually love using wet and wild. I only like some of their colors, but the brushes are nice and the price is right. :)
<p>I will be trying it this weekend for sure.</p>
<p>it was cool and pritty easy</p>
<p>What would happen if you added the eye shadow to colored nail polish you already have but it's too light and you just want to make it darker?</p>
<p>cooooooooooool!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!</p>
<p>i did not have a nail polish brush so i used a q tip it worked but u need a nail poilsh brush</p>
<p>wow!</p><p>that is cool!(=</p>
<p>This is soo coool im so gonna try it </p>
<p>This looks so cool and I am a big fan of nail polish and this will save a LOT of expense I will be sure to try it very soon! ;D</p>
You can put in a tiny metal ball to make the remixing easier.
<p>WAW! Thank You sooooo much I saved the trouble of my great expense and I am gonna make it with my friends to let them save less money and have GREAT quality like you and I</p>
<p>I use cheap nail polish all the time, it works very well for me.</p>
I read the first page of comments, but did not see the most obvious way to crush the eyeshadow. Use a PILL CRUSHER! It is very durable, inexpensive can be found almost anywhere, simple to use, no mess, easy to pour into funnel, easy to clean, won't hurt your hands, easy to clean, and small enough to store with your polish making materials in a makeup caddy or bag. <br> <br>The pictures below give you an idea of the various kinds of pill crushers available on the market today. As you can see there is one for everyone no matter what ailment you may have. They do make automatic pill crushers if you have problems with your hands. <br> <br>The first one is available at Walgreens for around $7. This is the one I use. It all comes as one piece that breaks down into 3 separate sections: the pill cutter on top, the crusher in the middle, and the drinking cup on the bottom. I found that to just use the crusher, the pill cutter is a real pain and is in the way and more difficult to use. I took it off permanently, but when I need to use it, I do not need to put it back onto the other two sections. It is still very easy to use without being attached to the parts.
Fantastic idea - thanks! (even two years later, lol!)
<p>Thanks, That was really helpful!!</p>
<p>I like this I am definitely going to try this</p>
:&quot;)
<p>What is bbs please?</p>
You could also put the eye shadow through a sieve first, to remove big lumps, then put it in the funnel :)
You can try to put the eyeshadow into a plastic bag and use a rolling pin to mash it up before putting it into the funnel.
They make solvent resistant glitter that won't break down. I found many varieties on Etsy. Plus color for polish. They also make a "suspension" fluid to make glitter polish that wont let the glitter sink to the bottom.
Some glitters dissolve into the polish and all you're left with is a slightly tinted bottle of polish.
Luv this. OBVIOUSLY gonna try this
Whenever I made glitter polishes the colored glitter I uses always dyed the clear polish and when I mixed it up it turned into a gross color, how do you prevent this?
I am so trying this its really cool!!!!! :):):)
so awesome! :D
I never thought of doing that! What a brilliant idea!
Soooo cool! Had to post this on my website, here's the link: <br>http://www.lescreateliers.com/Les_Createliers/Idees_Ideas/Entries/2012/9/6_Vernis_a_onglesNail_polish.html <br>Cheers, <br>Marie-Eve
defiantly going to try that I got loads of eye shadow that I have dropped and broke inside there cases, can never be bothered to use them as eye shadow cause the powder goes everywhere, cant throw them out like the colours to much, sorted nail polish it is then, cheers for putting this on although there maybe tutorials on line I wouldn't have even thought to look for it. wicked, :)
a custom color,Just an idea.it's a Great idea!!!
I've just tried this - it's brilliant - I had old 'Barry M' eyeshadows that I didn't use anymore, but now they have made fantastic nail colours. You're right about their slight matte-ness too, much nicer than a full-on gloss finish. <br> <br>One little thing, my eyeshadows were loose powder to start with, so didn't need crushing, which I reckon made it much easier: plus I had a tiny funnel that came with a cheap refillable perfume atomiser, these might be worth looking out for. <br> <br>Thanks so much for the inspiration :)
Fabulous!! Thank you :))) Another use for old eyeshadows other than to use them as mica powders. I hate waste xManuns
Just a heads up - adding bbs to your polish could ruin it. <br>I tried it , and the bbs rusted. <br>
This is WONDERFUL! I can't wait to try it.
My absolute favorite glitter. They have to best micro fine. I used it about ten years ago when I was a face painter. <br>Great ible. I have a niece who will be trying this. <br>Thanks.
Finally, a use for old eyeshadows!
@jessyratfink; Hi! Clever idea. I've tweeted it to my nieces and nail polish loving friends. Cheers! : ) Site
Sounds great! <br>My nail polish is always destroyd after washing dishes :(
A good base coat and top coat are helpful with this. Even cheap nail polish can last lots longer when you use a good base coat and top coat!
problem is the top coat doesn't work for me.<br>When I use topcoat, it chips even faster...
What top coat are you using? It might be worth it to try a new one. I'm really partial to quick-dry topcoats, but they range in price from fairly cheap to REALLY expensive. My three go-to top coats are Seche Vite (Around $8-10), Sally Hansen Insta-Dri Anti-chip top coat ($4-5, if I remember correctly), and ProFX Quick Dry High Gloss top coat ($5 at WalMart for a HUGE bottle). <br><br>Sally Hansen Insta-Dri doesn't smooth things out quite as nicely as the other two, but it's fantastic. The other two are wonderful at smoothing out bumpy nail art or rough glitters. All of them dry your nail polish to the touch within around a minute, and I wouldn't be able to actually wear nail polish without them.
I use topcoat from essence. <br>where do you buy your topcoat? <br> <br>BTW I love your easy ombre manicure :)
Thank you so much! I'm in the US, so I'm not familiar with shops in the Netherlands. I have to say, though, I'm jealous of your access to Essence products! We get some, but not as many and your products are often cooler! <br> <br>Are there any cosmetics stores near you? It might be worth looking to see what topcoats are available there. If not, just check the nail polish sections of your shops. I'm sure you'll be able to find something worth trying!
They are not really near me, I live in a small town, but when I'm in the city I usuallly go to a store where they have a few brands, but most of the time I buy essence, they have much cheaper stuff and I don't have so much money. :)
I understand completely. Polish can be expensive!
that's for sure!!!<br>
Have you heard of dish gloves?
You might be putting on the actual color and or the top coat on too thick, when I just put a layer or two of polish over mistakes it peels off in almost perfect sheets (without leaving a trace!) because it's just to thick...
About This Instructable
346,332views
736favorites
License:
Bio: part of the Instructables Design Studio by day, stitch witch by night. follow me on instagram @makingjiggy to see what i'm working on! ^_^
More by jessyratfink:no chill sugar cookie recipe Easy DIY Felt Coasters How to Choose Embroidery Floss and Fabric
Add instructable to:
