3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to make electric fan
  • 1 electric motor
  • 1 set of fan blades
  • 1 9V battery
  • 2 short sections of wire*
  • 1 case to house the motor and battery*
  • Note: Items marked with a * are only needed if a case is used.
  1. Take your fan blades and ensure they have a small hole or some way of attaching them to your motor.
  2. 2
    (optional) If there is no suitable way to attach them, use a small drill to make a hole that the motor spindle can fit through.
  3. 3
    Once you are sure that the blades can be attached to the motor, fit the motor into your casing, with the spindle poking out so the blades can be attached.
  4. 4
    Fit the battery in the same case.
  5. 5
    Connect the motor to the batteries and check that the motor works with the battery and that the motor is spinning the right way.
  6. 6
    Seal the case. If it doesn't clip together, you may need super glue or some other method to stick it shut.
  7. 7
    Attach the blades. You could clip them on if there is a tight fight, or you may need super glue.
  8. 8
    CONGRATULATIONS! You have now made your own electric fan.
  • Electricity is dangerous.
  • Use caution when handling batteries.
  • Do not disassemble batteries.
  • Do not recharge batteries (unless it is stated that it is safe to do so).
  • Do not dispose of batteries in fire.
  • Ensure batteries are installed correctly, observing the +/- polarity signs.
  • Do not mix used and new batteries or mix different types of batteries.
  • Batteries may explode or leak causing personal injury.
  • Always keep batteries away from small children.
  • If batteries are swallowed or lodged in the ear or nose, seek medical attention immediately
2 comments
Sep 12, 2010. 2:15 AMwareneutron says:
nice job kimpura
you have a slides show but composed one picture
thats great job . by wareneutron.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:adornakimpura
