Introduction: How to Make the Most Movie Accurate Arc Reactor EVER!
its here it is finally here the mother of all ARC REACTORS the god of mini arc reactor heaven the mark 1 movie accurate replica instructable is HERE!!!!!!! enjoy.
Step 1: What You Will Need.
so most of the things on this list could be found at michael's and the internet.
1.polymorph
2.sculpty or clay.
3.silver spray paint.
4. copper wire thin works best.
5. these pedicure tools i found around the house.
6. 11 L.E.D lights not dot it you will have to wire them.
7 a 9 volt connection thing.
8 copperish gold cole spray paint.
9 expandable stuff for a harness.
and make sure you have a TON OF CLAY.
Step 2: Getting the Look.
well sculpt a perfect circle of the polymorph for the clear ring then wrap copper wire around it
this process is very easy but takes forever. sculpt a small ring and make 3 pieces coming out
with the clay the size may vary depending on the size of your polymorph ring. then if you see the
pic you want every thing to fit then sculpt a circle bigger that the ring will 3 pieces but smaller that the
polymorph ring then just take a knife and gently push little lines all around it then bake the clay pieces.
Step 3: Wiring the Led Lights.
now if you don't know how to wire led lights either learn how or have someone do it for you. you
can also add that 9 volt connection make sure the wire is long so it can go to your pocket.
Step 4: Coming Together.
well now that you have made your clay pieces it is time for the gold piece in the middle of the reactor
this takes time just look at the picture and take your time you can do it.
Step 5: Almost Finished.
well now you will need a hot glue gun and just put the pieces together and make a casing out of clay.
Step 6: Done
and you are now tony stark i hope this has helped please rate this 5 stars and thank you.
here are some pics with the reactor and repulsors coming soon.
The Instructables Book Contest
