Introduction: How to Make the Simplest Electric Generator
Picture of How to Make the Simplest Electric Generator
i will show you how to make a generator easily.for this you will need common and cheap things.ihave given drawn pictures instead of real picture. so it may noybe so clear.with this generator you may not produce that much energy but still it may generate enough electricity to light up a led bulb.
Step 1:
Picture of
you will need the following things:
1)an iron nail of 15-20 cm.
2)a card board sheet.
3)a strong magnet.
4)copper wire of 28-30 gauge.
5)insulative tape.
6)led bulb.
Step 2:
Picture of
cut two circles of 3-6 cm diametre from the cardboard sheet.and now make a hole in the centre so that the nail can be inserted init.
Step 3:
Picture of
now insert the first circle in the nail ,3 cm away from the head.now insert the other circle in the nail in such a manner that the 2nd circle is 3 cm away from the first one.and put a layer of insulative tape on it in between the circles.
Step 4:
Picture of
now on the insulative layer between the circles put some copper wires 1000-1500 times by spinnig.now bring the two ends out.
Step 5:
Picture of
now connect the two ends to a led bulb.
Step 6:
Picture of
now take a magnet keep it almost 3-5 cm away from the nails head.now star to move it in various ways .at one time in a certain type of move the bulb will start to glow.here i have shown circular movement.then any time you may light it with that move.ifit does not work then try by changing the poles of led.i am sure that it is a project that may give you a first prize in science fair.
if i make any mistake inenglish forgive me because i am from a non -english speakin coutry.i am argha halder from naogaon bangladesh.i study in class 7 in biam laboratory school naogaon.
souravr10 (author)2016-10-13
inron nail matalab kill
this very intersting
divy patel (author)2016-06-16
what is meaning of iron nail in hindi
DivyamV1 (author)divy patel2016-07-03
lohe ki keel
mohd hashir (author)2016-04-19
cool trick
masterminecraft12 made it! (author)2016-04-06
Cool! This Worked And I Won First Place At The Science Fair!!!
Hello. I tried your generator but it didn't worked. Then I tries other working methods. And now I have my own idea. Anyways you help me a lot. I thick we have to scratch the wire ends for light to work. Add the statement of scratching the wire ends so this tutorial will be really very useful.
24 gauge wire will do? I have 50 meters
Will it work if rotate copper wire more than 1500 times? I have bought 50 meters for this. Will it work if I use two magnets, one up and one down?
Nibha (author)2015-08-18
can you tell me which type of magnet is used ?
swastika1 (author)2015-08-14
Argha, please give me two page description about this topic
Can I connect a motor to this thing instead of the led light? Can I use the power created by the generator to revolve a magnet around it, so that once we give it a start, it start automatically moving? Anyways it is cool. I think it is magnetic induction, right? You can contact me at my mail -
mohammedayazquadri@gmail.com
Thank you and sadly no, you can not add a motor, it is not powerful enough to rotate the motor fast enough to rotate the magnet. The induction also produces ac electricity, so it wouldn't work.
NeelanshuG (author)2015-05-22
Iqbal Samin (author)2015-03-06
hey, argha , i am from jessore bangladesh, plz send me a friend request on fb, my name is Iqbal Samin Prithul, and thnx a lot for the instructables
mahmoud.babosh (author)2015-02-26
Can you please tell me which kind of magnet should I use
Sniper13 (author)2015-01-21
it is cool
onkar.kasture.3 (author)2014-10-14
okay!
it would help me much THANKS!!
indigo401 (author)2013-01-30
This is great! Keep up the good work :-)
argha halder (author)indigo4012013-02-26
THANKS .I HOPE MY INSTRUCTABLES WOULD BE EVEN BETTER.I HAVE GIVEN A INSTRUCTABLE ON MAKING A BAROMETRE.IT IS VERY EASY AND OF GREAT USE.SO I HOPE YOU WOULD SEE THAT.
WOW ITS WAS GREAT! THANKS it would help me much
xxxSpox (author)2014-08-26
on an average basis....hw much power does it create?.???
argha halder (author)xxxSpox2014-08-26
It creates a very low ampere, but a decent voltage spikes around 3-4 volts sometimes. I didn't manage to check the spikes as I don't have an oscilloscope, but anything it produces is only powerful enough to light an led at most...
SHARMANATHAN (author)2014-05-26
Hi there. Can you kindly explain more on the turning.How does 2 ends coming out? i have used the cooper wire SWG18. it is quite thick and I can't make the LED function. Please explain it ASAP. Thank you..
sorry for the late reply,, but when you wind the wire you get the start and end of the wire, so there are two ends.. The wire you used is quite thick, you might try using 26 gauge wires. and wind it at least 1000 times,, not less. Then try it again,, i hope it will work then,, Good Luck!!
sahaab noor (author)2014-01-24
Wow like this but can i know from where i can get strong magnet? Any online website
salafrance (author)sahaab noor2014-03-31
Look for neodymium-iron-boron magnets. You may not need one to demonstrate this project, but they're fun in their own right. For example, if you hold a cylindrical stack of them in your hand and move around, you can *feel* their interaction with the Earth's magnetic field. Additionally, you can demonstrate electromagnetic braking trivially and in a way that becomes immediately clear to anyone observing, by dropping a button magnet down a copper pipe with a slightly larger inside diameter than the diameter of the magnet. I've tried this: it took about 40 seconds for the magnet to drop through a 4 foot pipe.
ThatCatMan (author)sahaab noor2014-03-28
You don't have to use a powerful magnet. Just any decent size ceramic magnet. You can find them at many different hobby stores, and they even sell these kind shown at Radioshack at a very low price.
sahaab noor (author)2014-01-27
Its great but i didnt understand step 6 pic!
argha halder (author)sahaab noor2014-01-27
sorry for that, in that step you just have to move the magnets near the nail in any pattern or movement. hope it helps
About This Instructable
263,391views
40favorites
License:
Bio: I love making and breaking electronics.
More by argha halder:Simplified Electronics: Microphone (DIY& How It Works)Slayer Exciter Circuit (Poor Man's Tesla Coil)Make a Metal Detector
Add instructable to:
