loading
Step 3: keep going
keep going along the long side lifting the lip up until you get to the corners.
If you take apart the $1 ones sold at target, they're carbon cells sealed in wax, very very messy. ;-(
I opened one of those up and I was like, &quot;WHOA!&nbsp;What is THAT?!!?!?&quot;. Instead of finding some nice little AAAAs, I found a nice little plastic wrapped block of chemicals or something.<br />
Some 9v batteries have loose AAAA cells in them between the jumper plates, others have the cells tied together with spot welded straps. You should be able to rip the straps off though. Yet other batteries have flat rectangular (rounded corner) cells. I've seen those loose, wax-dipped and plastic-encapsulated, depending on brand and/or type.
actually i used one of those battery's first but when it came to getting it out, the thing stuck so i had to delete all of the pictures and start again.
yes i got #<sup>%</sup>&amp;$ by a sunbeam. same type of cells. :-(<br/> <br/>
Seems I have messed it up. The batteries started hissing, with bubbling.
I think the silicon might be used to keep the plastic bottom from getting hot and melting. But what can I use those little batteries for?
as mini power sources
They are AAAA batteries.Not AAA batteries. They hold very little charge and cannot supply a good amount of current, so they cannot be used as AAA batteries.
The batteries are a replacement for AAA batteries.
the silicon stuff is to put pressure between the cells and the connections it is hard but squeezable.
they are almost the same length as AAA batteries, so you use the metal tabs stuck to the paper/cardboard as spacers, and use them as AAA's.
I use the case to house small circuit projects. If you make your circuit board the right shape and size, you can fit 5v regulators for power supplies or other small circuits inside of it, poke a hole in the bottom part for a wire to go out, and you can reuse the terminals to connect to a "real" 9v for power (or to a battery pack that has the same connector).
Oh, and Rayovac 9v's (fairly common) contain the stacked rectangular plastic-cased cells. I've taken apart two of them (dead ones) to use the case for electronics projects. These stacked cells are fairly useless other than as a 9v source, so I recommend using the battery first and then dismantling it for the case and terminal.
maplin do to does it say on the positive terminal "us patent no 5691079 pat .pend in several countries"
I'll probably sound stupid for asking this but what are AAAA batteries and what are they used for???
AAAA batteries are what you see in the pictures and are just the next size down from the AAA batteries.
a lot of low-power lasers use aaaa's
also compaq's tc1000 tablets use them for the pen
so ur saying i can take over the world by using low powered mildly annoying mining lasers??? my plans r finally becoming a reality!!!!!!!
lol!
i sound stupid too but are all the battery companys 9v batterys the same i mean do they all look like the one u took apart. i just dont want to open one and have some odd chemical start pouring on my hands and burn them.
if you don't find small batteries you'll find a wax block instead. its not a CELL its a BATTERY (batteries have cells in them) just don't go pulling apart the cells you find in there... unless you don't like your fingers.
You can use the ends to build a 9v connector for a project... just reverse the polarity as compared to a 9v.
you make this too complicated
<a rel="nofollow" href="http://www.metacafe.com/watch/360955/9_volt_battery_hack_youll_be_surprised/">9V hack</a>u can use the casing to hide ure money or anything u want just make sure it looks like a 9V battaery here a site that i got it from nvm cant find it SASUKE OUT<br/>
I opened one of these this way. After, when I was holding the cells, one actually exploded in my face!!! and it was a new battery!?!
ooooch
Which is why it would explode. <br/><br/>short circuit =&gt; heat =&gt; pressure = ...<br/>
You'll notice on the energizer's that the AAAA, are not true enclosed batteries in an air tight casing. They have an opening around the rim of the terminal.. Unlike the store bought version's.... the exterior 9V case does that job.... Often "budget" 9V battery's do not have the AAAA's, but rather a single cell filling the housing... I guess it's just cost effective/convienient, for larger companies to use them... I like AAAA's, very versatile when modding torches.... See how many AAAA's you can get in the same space as a D or even 3 x AA's...
The good ole' AAAA.... Nice ible.... Don't forget they are just as easy, if not easier to remove them from the bottom.. ;)
Are you saying that accidentally shorting the terminals with the pliers is a Bad Thing : ) ?
That's an added bonus.. ;) Perhaps why qqqqqq582 had an issue... sparks + open battery cells dont mix well sometimes.... ;)
Good!!! I like it!
i had huge problems with this before, but i figured it out. :-)
About This Instructable
44,022views
16favorites
License:
Bio: cheeze balls, mmm... cheeze...
More by merseyless:how to open a 9v battery
Add instructable to:
