Introduction: How to Properly Care for a Bearded Dragon
Picture of How to Properly Care for a Bearded Dragon
This Instructable will show and instruct you how to properly care for a bearded dragon. Everything from cage, food, water, decorations, and basic facts. The picture below is of my 12" long bearded dragon Lola.
Step 1: Basic Facts
Picture of Basic Facts
Bearded dragons are found in Australia in deserts and woodland. In the wild they will evade humans and often run up trees from predators. When confronted by a predator like a dingo or bird, they will sometimes puff-up and hiss to make themselves appear larger then they really are. Though they do not usually bite they are capable of biting. The males have black beards during mating season to attract females.
Step 2: Cage Size
The cage you will need for your bearded dragon is a glass fish aquarium. The size of the cage depends on your bearded dragon. I have posted a chart below for cage sizes.
XS beardies 2-4" 10 gallon
S beardies 5-7" 20 gallon
medium beardies 8-10" 30 gallons
L beardies 11-15" 40 gallon
Step 3: Substrate and Decerations
Picture of Substrate and Decerations
You will need some kind of substrate. Some people use reptile carpet but I have found that the best substrate is sand. Do not buy calcium sand from the pet store but buy children's play sand, its alot cheaper and is safe for the dragon. Put about 3" of sand on the bottom of the cage and smooth it out. After that but any kind of hide that you find at the pet store that is big enough for your dragon to be able to turn around while inside it. Then you might want to place some rocks are plants inside for show. You will need a big enough water dish so that the dragon can fit its whole body in but stand in it. I have a small water dish in the picture because my other one had a leak and I have to get a new one in a few days.
Step 4: Food
Picture of Food
Feeding is easy. Your dragon will eat mostly vegies but some insects. The usual is 70% vegies and 30% insects. For vegies mostly romain lettus, carrots, spinach, brocholie, and almost anything else. For insects crickets, superworms, waxworms, hornworms,silkworms, etc, remember to put calcium dust from the pet store on the crickets every now and then.
Step 5: Water
Water is easy fill the water dish with water every day and make sure it is always clean. Tap water is fine. Make sure you also spray the inside of the cage with a spray bottle to get some humidity.
Step 6: Handling and Cautions
Picture of Handling and Cautions
You can handle your beardie. They can get very tame and actually enjoy being around humans. Just hold them every day and work with them and they will become very nice. But while holding if your dragon becomes angry, put him/her back into the cage. Bearded dragons can not really hurt you, just scare you.
Step 7: Your Done!!!
That is all you need to know about care! The good thing about reptiles is all they ask for is your respect and care so if you keep them healthy and feed them, water them, and clean out there cage, they will show you respect to.
KelseyH4 (author)2015-10-12
Sorry, but this isn't a very good instructable.. It was very brief, unspecific and missing a lot of important elements, like how you should NOT use sand with young dragons because they can accidentally eat some up and become impacted. This is an issue with adults as well, however they usually can pass it since they are bigger. You did not go over proper food for a baby versus an adult. Babies typically get more bugs than greens because the bugs have more vitamins to help them grow strong, after they have reached their full size they typically will eat more greens than bugs. Your beardie looks under fed. I suggest feeding them the baby ratio of bugs to greens to get them back to their full size and color. You also did not go over proper temperature of the enclosure, basking lamps, locations and distance from basking are or types of lighting required. I am willing to bet that by just changing around your light and bulb set up, you can get your beardie looking a little bit healthier.
To any one who will read this for setting up a bearded dragon enclosure, please look elsewhere for more information, like here
https://www.instructables.com/id/Complete-Bearded-D...
IndigoOnion (author)KelseyH42016-06-07
You pretty much covered everything I was going to go over.
Please, no one follow this instructable
Nasubi77 (author)2011-05-09
Every single veggie you mention here is not healthy for a beardie. Use this site as a guide to know which veggies are healthy to feed your dragon (and which ones are not!): http://www.beautifuldragons.503xtreme.com/Nutrition.html
You should also clarify that baby, juvie and sub-adult dragons' diets are made MOSTLY of bugs and that they should have bugs every day. Usually around 50 crickets a day. A full grown adult eats mostly veggies and can get by on bugs every other or every few days for a total of around 50 a week.
Seriously, this whole Instructable sounds like advice from a pet store, which is almost always wrong.
000colin00 (author)Nasubi772016-02-10
Agreed
000colin00 (author)2016-02-10
You should NEVER use sand! Did you do your research or are you just being cheap??? Very brief, wrong info. Do your research.
izzayzayy123 (author)2015-02-01
all the veggies that you have mentioned aren't very good for beardies. please do your research before buying another animal
this beardie looks very unhealthy and thin. my beardie is colourful and alert. he is about 1 and a half
Faaun (author)2013-06-23
Sand is the WORST substrate for your dragon. Bearded dragons can't digest sand, calcium sand, or ground walnut shells, this leads to impaction. I suggest you do proper research before you go out and buy another animal.
Ghost Wolf (author)Faaun2014-09-01
You forgot about spinach. While it’s a good source of calcium it also binds with free calcium causing potential problems
Did you even research before you went out and bought a bearded dragon?
Adult bearded dragons eat 70% veggies and 30% insects. For baby bearded dragons it's reversed. Romaine lettuce has almost zero nutritional value, so it isn't recommended. Carrots contain a lot of vitamin A, and in copious amounts, it will kill your dragon. Carrots are good for them once in a while, they assist their eyes. Broccoli is toxic.And no, not "almost anything else" is acceptable for your dragon to eat. Research, please, before you kill your dragon.
care-bearded-dragons (author)2011-05-11
intresting article on bearded dragon care, but you have completely missed the UVB for the beardie, and you should not spray your dragon's cage for humidity.
You should not spray your dragon's cage for humidity. They need an arid environment and misting the cage can raise the humidity to dangerous levels, making them susceptible to respiratory infections. Since most dragon's won't drink standing water, the best way to keep your beardie hydrated is with a bath every few days or at least once a week.
radjadd (author)2010-07-04
cool instructable, your bearded dragon looks alot like mine in my instructables
johnfreitas (author)2010-01-13
well I'll try to be nice, you have completely missed the UVB for the beardie. Without UVB, your dragon will not grow very well it can and will be harmful to your Dragon. MBD (metabolic bone disease) is the effect of having no UVB. They will have very fragile bones and will die from it. And from what I can tell from your pics, you do not run one, very big mistake. So I guess anyone can post an instructable on here even if the info is completely off base.
MicahBeeman (author)johnfreitas2010-03-01
Agreed. You should've talked about basking lamps too for that matter. For a MUCH more comprehensive bearded dragon care Instructable, check out mine: https://www.instructables.com/id/Comprehensive-Bearded-Dragon-Care/
M4industries (author)2009-12-30
 You split an infinitive in the title.
flamesbane (author)2009-08-05
Those pebbles in the bottom of your beardies tank are asking to get swallowed, you should finely sift your play sand unless you want to run the risk of your beardie getting impacted (looking at your picture it looks like you are just using dirt?).
About This Instructable
25,378views
21favorites
License:
Bio: this instructable channel is here because i can never find good reptile care instructbles on here so every monday i will post a new instructable ... More »
More by coolherps1:proper care for a baby praying mantishow to properly care for a bearded dragonProper care of american toads (bufo americanus)
Add instructable to:
