iImage Information
This will show you how to put together a skateboard.I do suggest you at least wear a helmet because i recently was bombing a hilll and got speed wobbles and my head made contact first and i think i got a little dumber cause i can hardly talk
Materials:
.skateboard
.2 trucks
.4 wheels
.8 bearings(all in a pack)
.8 nuts and bolts (all in pack)
.griptape
.riser pads(optianal)
.13mm socket
.16mm socket
.3/8 wrench
.socket wrench
.drill with philips bit or philips screwdriver
Step 1Putting on the griptape
iImage Information
Unpeel grip tape and set the tips on the banked part of the board. Slam your hands down in the middle and work your way to the sides leaving no bubbles. Take a screw driver and rub the edges down so it outlines the board. Take a razor blade on the outlines area of the board at 45 degrees and cut all around the board. Cut off all the excess griptape.
-M
-M
i got a atm
what trucks are those, ventures are my favse
