You can add food colors or small flowers in order to make original paper for love letters, greetings, etc. (you can also store the remaining mixture for future paper-making).
Watch the video or follow that Instructable
Remove these ads by
Signing UpStep 1You'll need...
- water
- a frame
- tacks
- sieve (with holes of about 0.04")
- plastic sheets (cutted to the right side of the inner frame)
- a container (large enough to fit the frame)
- USED paper (newspaper in this case)
Just to help...
lol
1. You'll get a smoother sheet if you use a blender to disperse the fibres.
2. You'll get a much nicer sheet if you use something different to newsprint (commercially, old newsprint only ends up in roof insulation or cheap toilet roll). Try using the less-shiny junkmail you get.
3. As probably the only person here with a degree in Paper Science, I suppose I'd better get around to doing a proper Instructable about it...
....eventually.
let it sit in hot water for 24 hours
beat it with an egg beater till it is finer than pulp
follow the rest here!
i did that, and man, it was SMOOTH!
Although metal spoons are pretty stiff.
=P
I use small pieces of fabric cut from blankets. It's a lot cheaper and works better in my opinion.
I made a very similar instructable not too long ago, if you are interested you can view it here.
You'll notice that the side previously contacting to the plastic is extremely flat and shine =)
