Introduction: How to Renovate a Soundbooth Cheap
find a soundbooth in serious need of help
Step 1: Remove the Old Console Desk
Step 2: Recycle the Old Desk and Attach It to the Wall
i opted to have the redesign of the console desk be such that it is floating off the floor,, i will intend to replace the carpet later so all equempment should be elevated.. this also helps keep the equipment cool and mitigates the collection of dust..
Step 3: Relocate the Main Amplifier Bank
the main amplifier bank has loud noisy fans located inside of the amplifiers. it would help mitigate noise if the rear end of the amplifiers are located within another adjacent room..
so find a place and make a hole..
Step 4: Since We Have No Money...
i went downstairs to the movers and asked if they by pure chance had a computer server rack that someone had excessed.
OMG.. Skore!
they actually had a half rack that someone had just excessed the day before...
(i love that cool purple dinosaur) ((for the younger crowd, he was in a childrens book and his name was Serendipity)
with the half rack, i framed out a stand then inserted in the wall...
perfect fit!
Step 5: Move the Amplifiers
get them off the floor!
they have a new home now,
Step 6: Remove the Drop Ceiling? Really?
i was going to have contractors do this but 40 years of throwing cables over to make adhoc connections proved to be to much for the ceiling, as soon as i started poaking around, the mass of cables started to shift and the ceiling started to collapse..
so i started to pull out miles of old microphone cable and got to the real signal cabeling that connected the rest of the building to the soundbooth. the verified cables should be marked then coil up the leads and push them to the wall..
seeing th damage to the old drop acoustic ceiling, i decided to remove it myself and not wait for the contractors... it was a safety issue to start, then i realized i just save some money...
hmmmm...
Step 7: Have the HVAC Guys Remove the Air Ducts
they pulled them out and cut them to the walls then added a grate..
Step 8: Keep Going With Moving Cables
soooo many cables!
spend the next few days figguring out what connections you need and eliminate the rest.
in this case, i left the 40 or so balanced line cables that ran to the stage and other places in the theater space.
the old translation signal cables were no longer used so they had to go...
al in all, i removed about 2 miles worth of cable...
i was very sore afterwords...
Step 9: The Cable Race
there has to be a way to path signal cables to the console desk and the main patch panel..
i zipped down to the plumbers shop and got myself a couple of 8 foot 3 inch PVC..
when you cut it in half, i figgured it would make a perfect cable race.. so i tried it on the console desk
i like it
save the other pieces for the other races you need.
if the 8 foot length is short, simply use a coupler and cement two PVC pipes together then cut it in half..
i used a plug in circular saw..
it is easy to make a straight line on the PVC by placing it up aginst a door jam in the corner upright and drawing a line using the doorjam as a straight edge..
Step 10: Paint Your Space
i hate painting.. the painters can do this job..
dark walls light ceiling...
nuff said..
Step 11: Build and Frame Your Hutch
i had carpet comming in on friday and i still hadend even gotten the materials from the carpenters.. it was tuesday!
ugggg!
so i had my director buy the materials and i went in my car to pick them up...
Booo!
the next day i started to frame like a madman!
start by anchoring your anchor boards to the wall with toggle anchors (the walls are masonary)
i tried to get one in every 16 inches or so
when i was sure i had my anchor boards secured well to the wall, i started the build.
Step 12: Time for Carpet!
yea! carpet!
contractors again..
before the carpet, i hit the under side of the console desk with black spraypaint and i had to reset my table legs (3 inch PVC again) because the carpet people removed them to lay the carpet..
i ended up having to cut them a tad bit shorter to make them fit again...
then some touch up black again...
Step 13: Add Your Monitors
i made a seperate instructable for this one..
Step 14: Start the Next Phase... the System Backbone
i need a break!
thanks
3rd Epilog Challenge
