3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to repair a worn out clicker on an optical mouse
After five years in a university computer lab, this mouse wouldn't respond to clicks very well, but after this two minute repair job, it's as sharp as it's first day!
All you need is a bad clicky mouse, like the one pictured, a phillips screwdriver, and a nail file.
Step 1Remove the screw
remove the screw
There's only one screw in this model.
23 comments
May 15, 2012. 11:13 PMGmastefluffy says:
Worked way better then I expected, thank you!
Jan 16, 2012. 2:56 PMz1vot says:
Thanks, this tip was very helpful. Just repaired my left click. :)
Dec 30, 2011. 3:15 PMeen8egeweldig says:
It is funny because the mouse you used is the same exact model I have, very helpful!
Sep 21, 2011. 7:38 PMjmcguire pot farmer says:
ive got the problem of the left clicker hardly working i know its the case not the actual button inside its deffo the case button but i dont see how this will fix it as the mouse needs them sticky out things to push the button how is making them smaller going to fix it ive got blue tac on mine to make 1 of them sticky out things longer so it hits the button better
Jul 13, 2011. 10:47 AMmitchellsingleton says:
I was able to fill in the dimple with super glue. It creates a flat surface and just let it dry before reassembly. So far it is working great. I hesitated actually making the whole surface flat by remove height. Granted that i added height to the whole surface.
Jul 8, 2011. 6:48 AMgurcharan88 says:
my Microsoft mouse is deffer from the mouse shown here what should i do it has two problem 1 double click on left click and the other one is pointer not respond
Apr 14, 2007. 1:18 PMkkko says:
Thanks, that is great
Mar 21, 2008. 4:58 AMm_coomer146 says:
Do you know how to put the springs back in?
Dec 16, 2010. 10:41 AMntoogood says:
I'm sure you already found this out, but this page has a few mouse diagrams on it: http://www.dansdata.com/moremouses.htm
And another instructables site here may help:
http://www.instructables.com/id/Making-a-mouse-wheel-not-click./step4/Reassemble/
Dec 16, 2010. 10:33 AMntoogood says:
Thank you so much, that worked perfectly! I was surprised, because the divot/indentation was so small, but filing worked great. There were several small raised portions of the surface, at the corners of the area to be filed, that looked like they were part of the original manufactured part. However, filing those off did not cause a problem with clicking.
Jun 11, 2010. 4:29 AMtahibabal says:
wow it worked!!!.. my mouse broke, i click the left-click once but i went double click.. now, my mouse back to normal.. thx a lot ! , saved me 8$ or 75 thousand indonesian rupiah
Mar 16, 2010. 10:55 AMlbrewer42 says:
 This is brilliant, but I think I found a slightly easier way.  Since the parts you are filing off extend slightly higher than the dented area, I *think* these side parts are are there to prevent someone who is pushing down too hard from damaging the micro switch.  To eliminate the need to file anything, I simply cut a piece of duct tape into a tiny strip that would fit over the tiny indented area.  Of course I let some overlap so the tape does not come off and "form fitted" the tape along the sides of the plastic tabs so that it will stay there.  I just used a toothpick to press the tape down the sides of the tab.
I am thinking the duct tape will have enough cushioning to it that even if someone does press down too hard, the side projections can still help the switch not be ruined.
Of course I may also be wrong in my assumptions - however, the duct tape does work.  I did this to a Logitech Trackball mouse.
Thanks for making this 'ible!
Oct 29, 2009. 8:53 PMsl33p says:
SIR I JUST WANTED TO LET YOU KNOW, YOU ARE A GENIUS. I HAVE SEARCHED HIGH AND LOW FOR THE PAST YEAR FOR AN ANSWER TO THIS PROBLEM. AND NOW YOU, GREAT GOD, HAVE FOUND THE ANSWER!
Oct 27, 2009. 5:41 PMFatcat87 says:
Do you think you could take a few close up pictures of the "hard to put back" springs. I received a bag of parts for this mouse and a very sweet please and one of the springs has me stumped
Mar 10, 2009. 3:08 PMPuoskcud says:
The more Modern Dell (aka Logitech) Optical Mices have FOU (4) screws - two under the front sliding pad and two in the battery compartment under the "+" and "-" signs. They also have about a jillion parts, including a couple of springs on the side buttons, so dissamble them over a nice white sheet!
Mar 30, 2008. 6:54 AMadmiral001 says:
Thanks for the great tip. I tried this on my Logitec trackball and it worked like a charm. i was about ready to buy a new one, you saved me $40.
Mar 25, 2008. 8:43 PMjeandeau says:
Thank you for reminding us that often the problem is an easy fix of a less than obvious connection. I threw out my mouse thinking I would not easily find a replacement microswitch.
Jan 24, 2007. 1:53 PMroyalestel says:
This is a cool little idea. Thanks! I thought for sure you'd show how to replace a microswitch, but I like this much better!
Oct 25, 2007. 9:32 AMMojo_JoJo says:
Dang!!!.... I just replaced the micro switch of my mouse.
Sep 11, 2007. 3:00 PMCinshine says:
the wheel and springs fell out. I know it hard to put them back can you send me a picture on how they are supposed to go back in
Nov 16, 2006. 6:47 PMbenjgvps says:
heh, i just replaced my dell mouse because it would not work at all. the light won't work,buttons don't work, scroll wheel dosent work. i gutted it and it's in my junk box now.
Nov 19, 2006. 6:28 PMrnx says:
one of your USB wires was cut.
Mar 2, 2007. 7:53 AMbenjgvps says:
nope, I soldered on some new wires but that dosent work. it is a 3-4 mouse.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:pir8p3t3
