how to do send ns messages over a school net
 by BatchMan
Here is how to do lots of weird & annoying things over school net.
open run(start->run)type cmd.
follo instructions
ALTERNATE WAY TO GET A DOS PROMPT: Go to step 3.
Step 1: SEND them
open notepad.
type (no quotes): "@echo OFF
:start
netsend /domain message goes here
goto start"
replace message goes here with a message.
save to the desktop as annoy.bat
run it
(netsend * sends to all on a network...........LOL!)
WOKANDWAL says: Nov 21, 2012. 6:41 PM
how long does message last??
life-is-beautiful says: Dec 4, 2009. 3:34 PM
or to make it real easy just go to notepad and type in command.com
and save as a batch. the only problem with this is that when you close it you get that annoying not responding thing. and it works on any network
account3r2 in reply to life-is-beautifulJul 31, 2010. 3:28 PM
its not for "not responding", it says it needs more time to complete the operation, because you are supposed to use the command, "exit"
life-is-beautiful in reply to account3r2May 2, 2011. 1:47 PM
oh well i did not know that. thanks for clearing that up
furrysalamander says: Mar 26, 2011. 7:10 PM
is this traceable?
ReCreate says: Dec 22, 2008. 4:49 PM
It docent work,All it does is say that there is no function netsend
metrogdor22 in reply to ReCreateDec 1, 2010. 3:26 PM
He typed it wrong. It's actually "net send". Here's a better(in my opinion). Just copy and paste it into Notepad, and save as whatever.cmd
@echo off
:Start
net send /domain MESSAGE
pause
goto :Start
This is a little different, in that it pauses(says "Press any key to continue" so that they dont get a full screen of the same thing, just as long as u keep pressing any key.
DYLEGO in reply to ReCreateJan 14, 2009. 7:16 PM
you have to enable netsend. search in google
lanky.ninja in reply to DYLEGOSep 6, 2010. 12:55 AM
Is it possible for you to point more directly than google like an exact link, i've tried looking but can't find it :(
cammel8 says: Oct 9, 2008. 12:45 PM
Not to be mean or anything but, how is this "almost anything with windows and cmd" ? seems to me it is "how to send an annoying message with the netsend command on an internal network".
With a name like "almost anything" it might be helpful if you were to add commands you use at the run caommand.
Like:
CALC = calculator
IEXPLORE = internet explorer
SOL = solitaire game
FREECELL = freecell game
IPCONFIG = ip configuration utility
MMC = Microsoft management console
MSCONFIG = System Configuration Utility
TELNET = telnet utility
SYSDM.CPL = system proprties
REGEDIT = registry editing tool
CLEANMGR = cleanup utility
FIREFOX = firefox browser (if you have it installed)
And then explain how to use them contextually, like:
telnet 192.168.1.1
(will allow you to telnet into a router with the ip adress 192.168.1.1)
Or if you want to be more specific and actually want just cmd commands list them like:
ADDUSERS = Add or list users to/from a CSV file
ARP = Address Resolution Protocol
ASSOC = Change file extension associations
ASSOCIAT = One step file association
AT = Schedule a command to run at a later time
ATTRIB = Change file attributes
BOOTCFG = Edit Windows boot settings
BROWSTAT = Get domain, browser and PDC info
CACLS = Change file permissions
CALL = Call one batch program from another
CD = Change Directory - move to a specific Folder
CHANGE = Change Terminal Server Session properties
CHKDSK = Check Disk - check and repair disk problems
CHKNTFS = Check the NTFS file system
CHOICE = Accept keyboard input to a batch file
CIPHER = Encrypt or Decrypt files/folders
CleanMgr = Automated cleanup of Temp files, recycle bin
CLEARMEM = Clear memory leaks
CLIP = Copy STDIN to the Windows clipboard.
CLS = Clear the screen
CLUSTER = Windows Clustering
CMD = Start a new CMD shell
COLOR = Change colors of the CMD window
COMP = Compare the contents of two files or sets of files
COMPACT = Compress files or folders on an NTFS partition
COMPRESS = Compress individual files on an NTFS partition
CON2PRT = Connect or disconnect a Printer
CONVERT = Convert a FAT drive to NTFS.
COPY = Copy one or more files to another location
CSCcmd = Client-side caching (Offline Files)
CSVDE = Import or Export Active Directory data
DATE = Display or set the date
Dcomcnfg = DCOM Configuration Utility
DEFRAG = Defragment hard drive
DEL = Delete one or more files
DELPROF = Delete NT user profiles
DELTREE = Delete a folder and all subfolders
DevCon = Device Manager Command Line Utility
DIR = Display a list of files and folders
DIRUSE = Display disk usage
DISKCOMP = Compare the contents of two floppy disks
DISKCOPY = Copy the contents of one floppy disk to another
DISKPART = Disk Administration
DNSSTAT = DNS Statistics
DOSKEY = Edit command line, recall commands, and create macros
DSADD = Add user (computer, group..) to active directory
DSQUERY = List items in active directory
DSMOD = Modify user (computer, group..) in active directory
ECHO = Display message on screen
ENDLOCAL = End localisation of environment changes in a batch file
ERASE = Delete one or more files
EXIT = Quit the current script/routine and set an errorlevel.
EXPAND = Uncompress files
EXTRACT = Uncompress CAB files
FC = Compare two files
FIND = Search for a text string in a file
FINDSTR = Search for strings in files
FOR /F = Loop command: against a set of files
FOR /F = Loop command: against the results of another command
FOR = Loop command: all options Files, Directory, List
FORFILES = Batch process multiple files
FORMAT = Format a disk
FREEDISK = Check free disk space (in bytes)
FSUTIL = File and Volume utilities
FTP = File Transfer Protocol
FTYPE = Display or modify file types used in file extension associations
GLOBAL = Display membership of global groups
GOTO = Direct a batch program to jump to a labelled line
HELP = Online Help
IF = Conditionally perform a command
IFMEMBER = Is the current user in an NT Workgroup
IPCONFIG = Configure IP
KILL = Remove a program from memory
LABEL = Edit a disk label
LOCAL = Display membership of local groups
LOGEVENT = Write text to the NT event viewer.
LOGOFF = Log a user off
LOGTIME = Log the date and time in a file
MAPISEND = Send email from the command line
MBSAcli = Baseline Security Analyzer.
MEM = Display memory usage
MD = Create new folders
MKLINK = Create a symbolic link (linkd)
MODE = Configure a system device
MORE = Display output, one screen at a time
MOUNTVOL = Manage a volume mount point
MOVE = Move files from one folder to another
MOVEUSER = Move a user from one domain to another
MSG = Send a message
MSIEXEC = Microsoft Windows Installer
MSINFO = Windows NT diagnostics
MSTSC = Terminal Server Connection (Remote Desktop Protocol)
MUNGE = Find and Replace text within file(s)
MV = Copy in-use files
NET = Manage network resources
NETDOM = Domain Manager
NETSH = Configure network protocols
NETSVC = Command-line Service Controller
NBTSTAT = Display networking statistics (NetBIOS over TCP/IP)
NETSTAT = Display networking statistics (TCP/IP)
NOW = Display the current Date and Time
NSLOOKUP = Name server lookup
NTBACKUP = Backup folders to tape
NTRIGHTS = Edit user account rights
PATH = Display or set a search path for executable files
PATHPING = Trace route plus network latency and packet loss
PAUSE = Suspend processing of a batch file and display a message
PERMS = Show permissions for a user
PERFMON = Performance Monitor
PING = Test a network connection
POPD = Restore the previous value of the current directory saved by PUSHD
PORTQRY = Display the status of ports and services
PRINT = Print a text file
PRNCNFG = Display, configure or rename a printer
PRNMNGR = Add, delete, list printers set the default printer
PROMPT = Change the command prompt
PsExecv = Execute process remotely
PsFile = Show files opened remotely
PsGetSid = Display the SID of a computer or a user
PsInfo = List information about a system
PsKill = Kill processes by name or process ID
PsList = List detailed information about processes
PsLoggedOn = Who's logged on (locally or via resource sharing)
PsLogList = Event log records
PsPasswd = Change account password
PsService = View and control services
PsShutdown = Shutdown or reboot a computer
PsSuspend = Suspend processes
PUSHD = Save and then change the current directory
QGREP = Search file(s) for lines that match a given pattern.
RASDIAL = Manage RAS connections
RASPHONE = Manage RAS connections
RECOVER = Recover a damaged file from a defective disk.
REG = Registry: Read, Set, Export, Delete keys and values
REGEDIT = Import or export registry settings
REGSVR32 = Register or unregister a DLL
REGINI = Change Registry Permissions
REM = Record comments (remarks) in a batch file
REN = Rename a file or files.
REPLACE = Replace or update one file with another
RD = Delete folder(s)
RMTSHARE = Share a folder or a printer
ROBOCOPY = Robust File and Folder Copy
ROUTE = Manipulate network routing tables
RUNAS = Execute a program under a different user account
RUNDLL32 = Run a DLL command (add/remove print connections)
SC = Service Control
SCHTASKS = Create or Edit Scheduled Tasks
SCLIST = Display NT Services
SET = Display, set, or remove environment variables
SETLOCAL = Control the visibility of environment variables
SETX = Set environment variables permanently
SHARE = List or edit a file share or print share
SHIFT = Shift the position of replaceable parameters in a batch file
SHORTCUT = Create a windows shortcut (.LNK file)
SHOWGRPS = List the NT Workgroups a user has joined
SHOWMBRS = List the Users who are members of a Workgroup
SHUTDOWN = Shutdown the computer
SLEEP = Wait for x seconds
SOON = Schedule a command to run in the near future
SORT = Sort input
START = Start a program or command in a separate window.
SU = Switch User
SUBINACL = Edit file and folder Permissions, Ownership and Domain
SUBST = Associate a path with a drive letter
SYSTEMINFO = List system configuration
TASKLIST = List running applications and services
TASKKILL = Remove a running process from memory
TIME = Display or set the system time
TIMEOUT = Delay processing of a batch file
TITLE = Set the window title for a CMD.EXE session
TOUCH = Change file timestamps
TRACERT = Trace route to a remote host
TREE = Graphical display of folder structure
TYPE = Display the contents of a text file
USRSTAT = List domain usernames and last login
VER = Display version information
VERIFY = Verify that files have been saved
VOL = Display a disk label
WHERE = Locate and display files in a directory tree
WHOAMI = Output the current UserName and domain
WINDIFF = Compare the contents of two files or sets of files
WINMSD = Windows system diagnostics
WINMSDP = Windows system diagnostics II
WMIC = WMI Commands
XCACLS = Change file permissions
XCOPY = Copy files and folders
:: = Comment / Remark
Then explain how to use them contextually like:
ping 192.168.1.1 -t
(allows you to ping the ip address 192.168.1.1 with an infinite amount of pings until you cancel it 'cntrl+c') [helpfull to ping a router untill it comes back online when rebooting.]
ping 192.168.1.1 -n 3
(same as above but allows you to set number of requests so if you forget to shut it off, it doesn't ping infinitely.)
Just showing how to netsend is nice if it is the name of the instructable, but not if someone is expecting a list of stuff they could do.
Like I said, I am not trying to be mean, merely trying to give some constructive criticism.
Hope this helps in future structs...
RelyNupon in reply to cammel8May 3, 2009. 7:07 PM
aaaand... selection... apply... and print... lol that helps thanks
schetleft in reply to cammel8Feb 14, 2009. 6:00 PM
i'm copy-pasting that to a .doc file! lol i need the href-rence lol programming humor
DYLEGO in reply to cammel8Jan 26, 2009. 10:07 AM
That is the longest single comment I will ever see.
ReCreate in reply to cammel8Jan 15, 2009. 4:13 PM
ah yes taskkill.exe a way to close a program in gamemaker execute_prog(taskkill.exe,process name) it amasing how many thhings windows has built in
DYLEGO in reply to cammel8Jan 14, 2009. 7:18 PM
You must have had a long time yo post that!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
