Introduction: How to Solder for Beginers
Hey guys its Daniel from Thehackingguys.com and today I'm going to TEACH you all how to solder a wire for beginers so lets get right into it...
Step 1: Tools
Tools you are going to need are...
Step 2: Soldering Iron
The soldering iron is the most important tool for this and is a big must for every DIYER needs...
Step 3: Wire
Wire is important when you make a circuit
Step 4: Solder Them Up
solder is used to connect the wire with a good connection
Step 5: Soldering Iron Tip Cleaner
This will make sure that the tip of your soldering iron is clean
Step 6: Helping Hands
This tool will help you get extra hands when soldering
Step 7: Wire Stripers
This will strip off any plastic covering the wire
Step 8: Start by Striping the Plastic Off the Wire and Connect and Twist
twisting the 2 wires together is simply done by separating the wire inside and connect and twist
Step 9: Solder It Up
your wire is ready to solder just tin the soldering iron and add solder to the wire while applying heat
Step 10: You're Done!
This is Daniel from thehackingguys and I'll see you next time with another DIY
