Picture 2 is how the guide works ,pretty cool, huh!
you'll see something like picture 1.
now learn the lingo for your cube picture 2.
U. up as in the top.
B. back you don't need to know this for any movements.
L. the left side
R. the right side
F. the front side
D. the bottom side as in down.
If I have a ( ' ) mark after one letter in a sequence such as F U F' that means to turn that side that has the mark on it counterclockwise.
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_s e c o r e t
If I have a ( " ) mark after a letter such as U" D" L" R" B" F" that means to turn the side 180 degrees half a circle.
note: your rubik's cube might be slightly different then mine in the pictures all you have to do is think to yourself that the color I am using is the color you have to use for that.
Remove these ads by
Signing UpStep 1Step 1 the cross
1.All you have to do is select your color I chose green.
2.Find the center piece the one sided piece with only green on it.
3.Position that piece on tho bottom of the cube.
4.Now, look for one of the side corner pieces the these corners only have 2 sides it has to have one green side on it.
5.It will have another color on the other side I don't know that color is so I'll represent it with a ? mark.
You have to take ? and green and find the same colored center piece as the ? is. Try to get those 2 colors matched up like in picture 2 you can see the center blue and the corner green and blue are matched up and in place.
6.Once you get them matched up all you have to do is rotate that side until the greens come together on the bottom.
repeat steps 4 -6 until you have a cross.
I'm sorry I cant explain this better I know I had a very hard time with this step for a while but once I got it I can get this step done as fast as I can find the colors.
the rest will be a little easier.
Really nice tips! Rubik's Cube tips
majorson.
it will mess up the cube, to do the next corner jsut turn the top layer to the next one and do the movement you didn't use the first time, you just cannot use the same move 2 times.
If you use pic 1 first use pic 2 on another corner.
If you use pic 2 first use pic 1 on another corner.
You can make one here
http://www.instructables.com/id/DIY---Rubiks-Cube---Blind-Mans-Cube---Metal-Rubi/
