Introduction: How to Stop Squeeking Door Hinges
this instructable is about how to stop those annoying door hinges from squeeking(for temporary use)
Step 1: Step 1 Things You'll Need
things you'll need-pam-an old rag u don't particularly care about
Step 2: Step 2 Spray the Door Hinges
i like to spray the inside as the following pic shows but usually that does the trick but if t still squeeks try spraying the out side of the hinges
sry that the things not in focus i couldnt do it with 1 hand
Step 3: Step 3 Wiping It Down
now the last step just wipe the grease from the door and hinges. note; there will be some old black grease stuff, wipe that off as well
jaemiker (author)2011-10-04
WD-40 is the magic weapon against anything squeaky.
log63 (author)2008-07-05
Yeah, I don't see why you wouldn't just use some WD40
rimar2000 (author)2007-08-14
I use soap. Also liquid soap.
lemonie (author)2007-08-13
You want some kind of machine oil (not WD40, or vegetable oil). 20W40? L
dacker (author)2007-08-13
Pam's soybean-based oil probably will not be a good long-term solution and can go rancid.
IMHO, you would be better off getting a proper mineral-based lube for a permanent solution to a squeeking hinge. I usually use Tri-flow, the mineral- and Teflon-based lube I use on my bike chain.
Vertigo666 (author)dacker2007-08-13
WD-40?
dacker (author)Vertigo6662007-08-13
Mentioning that product has been known to cause flamewars! <grin> Is it really a lube, or is it something else? <rhetorical><br/><br/><a rel="nofollow" href="http://www.wd40.com/AboutUs/our_history.html">History of WD-40</a><br/><br/>
perhaps.
Kiteman (author)2007-08-13
Needs a little editing (such as removing the duplicate "step 1"), and can you change the font back to normal? The "typed" stuff shoots right off the side of my screen.
About This Instructable
1,858views
3favorites
License:
More by Huray4Insanity:how to stop squeeking door hinges
Add instructable to:
