3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to turn your guitar from mono to stereo
Ok this instructable is all about tuning a mono guitar to a stereo guitar and im not talking about a mono to stereo cable splitter or an A\B switcher no im talking about the neck and bridge pick up each having there own amp either at the same time or separated this opens a whole new world of ideas and possibility's
Step 1Who are your helpers
who are your helpers
tools!
Screwdrivers flat head and philps
a soldering iron and solder
wire strippers
diagram
wire!
electrical tape
a towel and something like it to put the guitar on
an extra hand if you can get one
wire cutters
needle nose pliers (not needed but helps as an extra hand)
a wrench to get the knob nuts off
paper and pen (to write it all down so you dont forget what you did and how to write an instructables)
and an hour and a half of time
25 comments
Oct 21, 2010. 6:58 AMjust_lorenzo says:
Hi Megatronix, I invented "natural stereo" pickup to get the best stereo. 12 mini-coil pickup to read the string movement. When you pulse a string the moviment is up, down, left and right. Actual pickups just read the up and down moviment. Visit my site and listen the demos. Look also the osciloscope to see the stereo amount. www.pauls3dsystems.com enjoy "natural stereo"
Jun 18, 2011. 2:35 PM1spartan95 says:
Awesome!
Apr 11, 2010. 12:05 AMRF567 says:
 I don't get the diagram. where is the tone control and why are the wires from the PU selector going to the output on the volume controls?
Apr 9, 2010. 6:01 PMRF567 says:
 assuming that the diagram for this is at [URL]http://www.guitarelectronics.com/product?WD2HH3L11_00/Guitar_Wiring_Diagram_2_Humbuckers3Way_Lever_Switch1_Volume0Tone000.html
[/URL]
Could you draw on this and show us what it would look like in a diagram?
Apr 9, 2010. 7:10 PMRF567 says:
 Or maybe you could put a video of this on YouTube? No-one has put anything on YouTube about changing a guitar from mono to stereo
Apr 9, 2010. 2:39 AMRF567 says:
 I found a diagram at www.guitarelectronics.com/category/wiring resources/ and found an appropriate diagram. Do you mean to solder another wire onto the pin that is linked to the volume?
Apr 9, 2010. 2:50 AMRF567 says:
 or do you mean that the two middle pins were joined and you want to separate them?
Apr 8, 2010. 1:01 AMRF567 says:
 Its an 8 pin switch just like the one in your diagram. Is it possible to take a picture or even a video of this particular step?
I emailed the guys at irongear.co.uk because they create circuit diagram lists, and asked for them to produce a diagram with the specs i sent them so i had an idea what all those wires in a big mess go to where in the circuit.
Do you know what each pin on the pickup selector does? That would be really handy
Apr 7, 2010. 5:48 PMRF567 says:
I don't entirely understand step 4. Could you please elaborate a bit more, but otherwise this is a great instructable.
Also, I have a H - S - H pickup layout and there's heaps of wires everywhere (because the nincompoops at Ibanez who made the RG series made a mess of the wiring), I was wondering if the same principles apply or if not, how would you go about doing this step?
Feb 23, 2010. 1:32 PMGlockenator says:
I cut the wires going to the jack, and soldered another jack to it, and then drilled a hole on the side
Feb 23, 2010. 8:11 AMGlockenator says:
is the cat optional? cause i dont got one
Sep 1, 2009. 6:01 AMiamtoats says:
That's similar to what i am trying to figure out. A friend and I are trying to get the pickups on different channels of a stereo jack, so we can switch between them really fast (with a foot switch) and not have to worry about taking our hands off the strings. (mostly fast metal stuff... I like to use the neck pickup for anything above the 10th fret....)
Aug 2, 2009. 11:40 AMgabrielG2 says:
Words from a Luthier... That stereo wiring is, as said above, technically wrong. The correct way is to make the "whole" sound of the guitar be panned Right, mid or Left. Correcting what Metal-Matt said, active circuits use lower ohm potentiometers (generally 25k). Guitars pickups expect a high impedance, and even your cable can mess with your sound. Generally the active circuits are only a buffer with high input impedance and low output impedance. That makes your sound "invincible" And.. your soldering skills needs improvement. The GND solder you made in the pot is real bad. Try using a higher watt soldering gun and less solder. Greetings from Brazil! And sorry about the not-that-good-English.
Aug 2, 2009. 6:17 PMgabrielG2 says:
its very hard to damage a potentiometer when soldering its carcass, UNLESS its a Push-Pull DPDT Pot. if you need some help, don't be shy to ask me. I can even make a instructable of some sort...
Jul 29, 2009. 1:09 PMpdub77 says:
Really interesting idea! Awesome.
Jul 28, 2009. 7:56 AMshyguy52 says:
lol "the cat that only guarded the wire"
Jul 27, 2009. 10:32 PMcharlieb000 says:
sometimes(or always - not sure) picups are wired to cancel out mains frequency and other unwanted freq.... so maybe best to keep them together... just make a balance knob like on stereos with the centre wiper the soucre (maybe a resistor to gnd on each output to keep the other chnl silent) - but this might make your output weaker.
Jul 26, 2009. 10:43 PMtubbychick3n says:
". . .a whole new world of ideas and possibility's" It's spelled 'possibilities'
Jul 27, 2009. 11:58 AMtubbychick3n says:
I'm pretty sure you can go to your instructable and edit it to fix this if you want.
Jul 26, 2009. 9:20 PMmetal-matt says:
uhh, good idea.. but... you switch bettween the pups for differant tones, they make differant sounds... so by doing this, it will just make it sound like you allways have the switch in the middle... not so good when you want to make some types of sound. i play metal, and i basicly dont use the neck pup, so this would just make one side of the stereo (for me) sound muddy... its a good idea, but i think it would better if you coil splitted your pickups and used either side of the humbucker for the L and R, but mind you, your pups will sound like a single coil pups then, not that humbucker sound. ohh, and the whole 250k, 500k pot thing, well thats just preferance. i think all my guitars have 500k, but ther rock/metal guitars so they should, older rock/blues guitars should have 250k, it gives a smoother sound. active guitars however, go higher, with stuff from 1meg, to i-have-no-idea. thats cos i dont like actives, heheh. but well writen, awesome photos. good instructible.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:megatronix
