Step 6Say hi to jack
T - Tip
S - Sleeve
on your package that you got your 1/4 jack it should tell you where R T S is if not look at some pictures below
first thing your gonna do is grab the two wires you soldered on to the vol knob and also a wire that came off of the tone knob that you cut off in the beginning it should have two wires in one
after you got all the wires your gonna use take on wire such as the one you soldered from the output of the new vol knob and then solder that wire to either the Ring or Tip i have mine attached to the Ring it doesnt matter though
next take the second wire the one with two wires in one wire and your gonna use the wire that has insulation on it the outer wire is called a shield wire or a ground wire, but take the inner wire and solder that to the other Tip or Ring which ever one is free
and then lastly take both ground wires and solder them to the sleeve
[/URL]
Could you draw on this and show us what it would look like in a diagram?
