Step 9The hard parts over but there are problem!
time to put it together
so if you had some problems puting it together cause i had a few too
one problem was my vol knob was the wrong size but not a big problem so i fixed it by takeing off the spacers and shoving it in and was able to get a few threads on
another problem was the guitar in general! cause if your guitar has major feed back problems this is not gonna fix it sorry
and a big problem for me was the jack when i put it in it was a bit tight so it ended up shorting out and not working right but i fixed it with a drill and some sort of carver looking thing i found in my garage
so then thats it i hope it works for everybody its a whole new way of playing if you have any questions leave a comment!
a few things that i did also you necessarily don't need to do i did it because i wanted to try new things such as tin foil, my guitar has crazy feedback and i don't wanna replace my pick up's i heard that if you put tin foil on the plastic lid for the guitar that it helps well it didn't !
another thing i did was to my switch i cut the bridge between the outer wire inputs and what that did was instead of being able to play both pick ups at the same time it now only plays one at a time through each amp so what i can now do is have one amp play full on distortion and the other will be clean while the middle of the switch is a complete kill switch now so i don't need to use a stomp box to switch between clean and distortion or i can use an fx pedal on one amp so many different things to try
Add Comment
