Step 2: Paring knife
This one is a little tricky, but easy to get once you've done it a few times. You want to cut off strips of zest, but avoid as much of the pith as possible. You'll always have a little on there, though.
I start by cutting off the top and bottom of the fruit so that I can see where the skin ends and the pith begins.
Place your knife right at the edge of the skin and guide it down and around the curve of the lemon. The amount of pith left on mine is really the most you'll ever want to have, any more than that and it can effect the taste of your zest!
Big strips look the best, but you can always slice off the skin in smaller pieces if it helps you get less pith. Depending on what you're using the zest for, you can leave the zest in big strips, julienne it, or chop it finely.
westfw says: Aug 17, 2012. 1:54 PM
I've done this "backward." Peel the lemon (pith and all.) Then, starting from the backside, cut/scrape off the pith to leave nothing but the zest. This works well for making candied lemon peel, but I always feel like it's not finely enough grated for recipes that call for "zest."
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
