i am canadian's AST Pistol Mod
 by silencekilla
i was having trouble getting the firing pin to pull back on his gun without sharpening the firing pin. and i didnt want to sharpen it so for those of you who may have had the same problem... this is for you.
Step 2: Taking it apart
This part is simple if your carful. SO FOR GOD'S SAKE BE CARFUL OR A BIG SCARRY MONSTER WILL EAT YOU!!!
Step 5: Loading
wats-a-username says: Sep 7, 2010. 4:44 PM
i hate using green rods for ammo so ill stick with yellow rods
martiener1 says: Jul 13, 2010. 1:24 PM
another bullet: green rod - orange connector - white rod - dark grey connector
Spycrab says: Dec 7, 2009. 6:28 PM
XD
rofl
~Aeronous~ in reply to SpycrabJan 7, 2010. 5:09 PM
 roTfOl.
pk_excel says: Jul 19, 2009. 8:47 PM
can someone find a way to fix the red connector problem on this gun? I tried this instructable, but with the decapitated grey on it fires 2 at a time.
DB9 in reply to pk_excelDec 19, 2009. 3:47 PM
thats a good thing though if u extend the size of the mag
lioneatr says: Oct 26, 2009. 12:57 PM
 or you could of used oblivitus's fix
sukinmaru says: Oct 6, 2009. 4:06 PM
Looks awesome. Need more photos & instructions though... 4/5
gtrain says: Aug 13, 2009. 7:11 PM
only use rods. the ammo you have is heavier and you can't fit as many in the mag.
rexdino5 says: Jul 6, 2009. 12:14 PM
What does ast stand for?
Raikou-san in reply to rexdino5Jul 19, 2009. 6:28 PM
Assault
KnexMaster7000 says: Jun 20, 2009. 7:53 PM
THANKS SO MUCH! dude this rocks cuz i was about to smash this gun to pieces i was getting so pissed off. you are fricken awesome. and thanks knexguy cuz i really need those grey peices so thanks for reminding me. :) 5 stars
The_Lost_Carrot says: May 22, 2009. 10:14 AM
thanks this works really well cos i was really pissed of when i made this cos it didn't work but now it works perfectly !!!
knexguy says: Dec 30, 2008. 2:59 AM
I wouldn't use the double ended grey ones, the end that is hit by the pin will split.
RMConstruction in reply to knexguyMay 15, 2009. 9:55 AM
a way to make decapitated greys i suppose
knexguy in reply to RMConstructionMay 16, 2009. 1:05 AM
Not really, the grey will just get cracked. It is easier to then bend it apart than cut it I suppose.
DJ Radio says: May 6, 2009. 4:39 PM
this mod isnt needed, you just twist the pin.
Miles Tails Prower says: Jan 3, 2009. 8:18 AM
DUDE, you don't even have to sharpen the pin, just tape the tip with clear tape!!!
Ikedog1995 in reply to Miles Tails ProwerFeb 13, 2009. 3:29 PM
the reason he made this was because sometimes the firing pin wont pull back because its caught on one of the bullets. but if you twist the firing pin while you are pulling it back, you wont have that problem.
Miles Tails Prower in reply to Ikedog1995Feb 14, 2009. 12:47 AM
No mods are needed. Just use clear tape to tape the firing pin, you will cover the grooves, so the problem stops.
Ikedog1995 in reply to Miles Tails ProwerFeb 14, 2009. 9:37 AM
but i do agree, this mod isnt needed
Ikedog1995 in reply to Miles Tails ProwerFeb 14, 2009. 9:36 AM
i tried that but the tape gets pushed down into the grooves and if you use too much tape it will be too thick and wont fit into the barrel.
Miles Tails Prower in reply to Ikedog1995Feb 14, 2009. 10:06 AM
Jep.
pls says: Dec 29, 2008. 4:35 PM
Whats different, the ammo/mag?
RMConstruction in reply to plsDec 30, 2008. 2:59 AM
Yeah, i don't understsand. All you really did was make bigger and change one part.
pls in reply to RMConstructionDec 30, 2008. 10:11 AM
ya.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
