[i-ponic] Cheap I-kea Areoponic Propagator
Introduction: [i-ponic] Cheap I-kea Areoponic Propagator
This is my tiny project for an areoponic propagator for seedlings and also for clones.
I made this with an i-kea samla box (box and cover) 3.99$
A miny air pump (aquarium ones are good) 10$
Aquarium stone (for air bubbles) 2$
Mini pots ( the ones with holes, like hydroponic ones)  0.3$*8 = 2.4$
Silicon tube (about 1mt) 0.5$
Expanse clay (holds the plants in the pot)  4$
Whole project BOM costs about 23 $$
Hope you enjoy!
Step 1: Drill the Holes for Your Mini Pots and for Air Tube
Drill many holes for number of seedling you want to set, in my case 8
Drille the hole on one side of the box, so the air tube can go into it, pay attencion to not drill a too large hole.
Step 2: Connect the Air Pump to the Stone
Connect the silicon tube one side to the air pump the other to the stone (aquarium stone), fill with water and turn the pump on, so you test if water level is high enought.
Bubbles will come out
Step 3: Put Your Seedling :)
Now it's time to put your seedling into place! For better initial growth use rockwall or cocoPellets, fill the space between cocoPellets and the minipot with expanded clay so the plants wont fall on one or other side.
Ready it is! watch your tiny plants grow! and only for 22$$$$!!!
Step 4: Watch Your Plant Grow!
After a few days you will see bigger plants and good white roots!
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Does the water come all the way to the top of the black pot, or how deep does the pot set into the water?
    The single pot is 5cm diameter, and about 6cm tall. The water comes all the way across the black ikea box as form of tiny bubbles.
    If you plan to use this as propagator use the 14 cm Samla box, and a small pump will be fine.
    To answer directly your question i have water drops everywhere in the box!!
    Hope you got what you needed,
