This was a class project for GEEN 1400 at the University of Colorado-Boulder, Craft Technology Group (www.cs.colorado.edu/~ctg)
The idea behind this idea is to create a new way for a person to express his or her music while on the go. We like to think of this project as the current generation's way of walking around with a boom-box on your shoulder.
The iBeat Tee is standard t-shirt that has a completely removable front panel (meaning that all the electronics are fully removable for washing of the shirt) that lights up according to the beat of music coming directly from the user's MP3 player much in the same way the equalizer does in your media player on your computer.
The iBeat Tee takes input from a user's MP3 player and measures the magnitude of the peaks and troughs of the selected music. We then have written and program that dictates which and how many lights to illuminate on the shirt based off of the magnitudes measured.
The iBeat Tee is designed in a way such that the user can keep his or her MP3 player in his or her pocket while wearing the Tee and so that the user can be using headphones or speakers while the shirt is still in use.
This specific Tee has a cityscape design to it. Feel free to change the design however you wish, though for the purposes of this Instructable the steps will be designed specifically to give guidance on how to build a Tee with a cityscape design.
NOTE: We strongly suggest you look at/do our VU Meter Instructable as we feel it will make this project much easier. Here is the link:
http://www.instructables.com/id/VU-Meter/
For this project you will need:
-Four (4) 9V power inverters with 9v snap connectors on one end of each
-One (1) black t-shirt
-Two (2) 11x16 inch pieces of black fabric
-One (1) 11x16 inch piece of Heat N' Bond Iron-On Adhesive
-One (1) 8.25x6.5 inch piece of blue fabric
-One (1) 8.25x6.5 inch piece of Heat N' Bond Iron-On Adhesive
-One (1) Size A4 Cut and Shape EL Sheet (phosphorescent blue-green)
-One (1) Size A4 Cut and Shape EL Sheet (Pink off - White on)
-Nine (9) JST 2-Pin Connectors
-Approx 25 feet of solid or threaded wire (one color)
-Approx 25 feet of solid or threaded wire (different color)
-Heat Shrink
-Thin-Width Masking Tape
-Conductive Tape
-Electrical Tape
-Needle and Black and White Thread
-Needle Nose Pliers
-One (1) Relay-Super Glue (or equivalent)
-Razorblade
-Two (2) 3mm Bright White LEDs
-Soldering Iron
-Solder
-One (1) 3.5mm Male to Spade-Tongue Speaker Cable (At least three feet in length)
-22 gauge solid wire
-One (1) EL Escudo
-Breakaway Headers - Straight - Strip of 40
-One (1) ArduinoMega
-Velcro
-Four (4) 9V Batteries
Remove these ads by
Signing UpStep 1Cutting the Design for the Cityscape
-One (1) 11x16 inch piece of black fabric
NOTE: For this step you will be asked to user a Laser Cutter. If you do not have access to a Laser Cutter or simply do not wish to use one you can always cut the design out by hand. If you do end up using a Laser Cutter, we have attached the design files the Laser Cutter will need to create the cityscape.
Iron the Heat N' Bond, paper side up, to one side of the blue fabric.
Using a Laser Cutter and the supplied designs (attached) cut out the cityscape design from each the blue fabric and the black fabric. MAKE SURE that you cut out the design with the actual building shape from the blue fabric and the design with ONLY the rectangular windows from the black fabric.
EL shirt layout 1.svg(1728x864) 294 KB| « Previous Step | Download PDFView All Steps | Next Step » |
the wires to the tape? and where do you connect them?
lol good idea :)
I was wondering if a jacket would make for a more comfortable design (putting the actual EL design on the back) since there would be less stress on the body, plus, the batteries could be stored in a pocket. All I see you might have to do would be to extend the wiring so all of the components were on the front side flaps of the jacket so they did not get crushed when one went to lie back in a chair
Thanks
Also here is the direct link to the connectors: http://www.sparkfun.com/commerce/product_info.php?products_id=8670
Thanks for your feedback
Pragmatically, how comfortable is the shird to wear? The panel doesn't look particularly flexible in the images, and there's a fair number of wire connections and solder-like bumps.
Zack
As to the flexibility of the front panel it is really unnoticeable unless you bend all the way over. However, for just wearing to walk around the current flexibility capacity makes for it to be comfortable to wear in the front.
Thanks again and please let us know what you think so we can make our next design even better!
