Step 2: Cutting the EL Sheeting
-One (1) Size A4 Cut and Shape EL Sheet (phosphorescent blue-green)
-One (1) Size A4 Cut and Shape EL Sheet (Pink off - White on)
NOTE: If you do not already have a source to get EL Sheeting, we got our EL Sheeting from: Electro Luminescence Inc. : http://e-luminates.com/osc3/index.php
Cut out seven (7) 0.5 inch by 8.5 inch strips of EL Sheeting from the "pink off - white on" EL Sheet. MAKE SURE that there are is a positive lead on one end and a negative lead on the other end on each strip of EL Sheeting that you cut. If there is not the EL Sheeting will not work. These will be the different "floors" in building.
Next, cut out one (1) 4 inch by 8.5 inch rectangle of the "phosphorescent blue-green" EL Sheet. This will be the lake.
Next, cut out one (1) 3.5 inch by 3.5 inch square of the "phosphorescent blue-green" EL Sheet. This will be the moon. IMPORTANT: make sure that at least one (1) side of the square has both positive and negative leads on it.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
